Head Light Wiring - Chevelle Tech
post #1 of 4 (permalink) Old May 19th, 14, 10:03 AM Thread Starter
Head Light Wiring
Hi! I am rewiring the head lights on my 67 SS as per the diagram in the AIM. I am not the best with electrical stuff but to me it looks like the light green wire is spliced between left side high & low beam lights then heads to the right side low beam and back to the junction block. Am I correct in assuming that is a splice??? It is on UPC 12 D1.
Thanx
John 67 SS is offline
post #2 of 4 (permalink) Old May 19th, 14, 11:10 AM
Re: Head Light Wiring
Light green should go to all four sealed beams for bright lights.
This is a 69 but should be the same as far as I know.
post #3 of 4 (permalink) Old May 19th, 14, 11:24 AM
Bryan
Yep---that diagram will work.
The low beam lamps on a 4 lamp system actually have a low and hi----that is why the green wire goes to all 4 lamps.
The tan wire only goes to the outside (or upper in the verticle orientation)
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
Bryan59EC is offline
post #4 of 4 (permalink) Old May 20th, 14, 10:15 AM Thread Starter
Thanx Guy's!!! Hope the light green & tan are still distinguishable in the 47 year old wiring harness towards the fire wall!!!
This Thread is more than 1832 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
