1964 amp guage shunt - Chevelle Tech
post #1 of 4 (permalink) Old May 15th, 14, 1:08 PM Thread Starter
Randy
Some one please help me.
I need a shunt for my 64 chevelle SS It has gauges and this year alone. They were also used in 62 thru 65 novas with gauges.. The shunt is mounted on the core support under the horn relay. I have looked with all the vendors. Does any one have info on this item? I just missed the one that was on ebay. An nos item. Thanks Randy
Woody1000 is offline
post #2 of 4 (permalink) Old May 15th, 14, 6:34 PM
Re: 1964 amp guage shunt
Randy, Not sure about 64's but on a 65 there is no actual shunt per se but rather it is the red 10 gage wire that runs from the terminal block on the core support behind the battery and is terminated at the horn relay.
USAF Retired (1968-1988)
David Bates is offline
post #3 of 4 (permalink) Old May 15th, 14, 8:20 PM
Dave, 1964's are unique. The original poster is correct, an external shunt is needed-- looks Like a ballast resistor only green in color. Tough to find, yes.
Coppertop is offline
post #4 of 4 (permalink) Old May 16th, 14, 7:36 PM
grr
I found this...It is being re-popped
http://www.classicmuscle.com/p-11173...sistor-ss.aspx
Gary
grr456 is offline
This Thread is more than 2155 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
