Factory Tach Wiring - Chevelle Tech
post #1 of 6 (permalink) Old May 15th, 14, 10:32 AM Thread Starter
Larry
Factory Tach Wiring
I have a '64 Elco with a factory tach and no wiring. There are three studs on the back of the tach but are unmarked.
Anyone know which takes 12V and which takes the coil feed? If I hook it up wrong it will cook it.
Thanx
OkcLarryD is offline
post #2 of 6 (permalink) Old May 15th, 14, 12:49 PM
anthony
Re: Factory Tach Wiring
Top stud with red plastic colar to dist. other stud with red plastic collar to 12v mulit. color. brown wire for dist.
amduran is offline
post #3 of 6 (permalink) Old May 15th, 14, 8:21 PM Thread Starter
Larry
Two wires to the distributor?
How does that work and do they both go to the neg post?
post #4 of 6 (permalink) Old May 16th, 14, 6:44 PM
grr
I asked the same question here......
https://www.chevelles.com/forums/showthread.php?t=614810
My harness only has 2 wires, though.......
Gary
grr456 is offline
post #5 of 6 (permalink) Old May 16th, 14, 7:19 PM
Frank Riley
Moderator, how about moving this tread to Electrical & wiring...?
70-454 LS5
Mid America Chevelle Club #293
Greater Kansas City
70-SS454 is offline
post #6 of 6 (permalink) Old May 17th, 14, 6:58 PM
If this is correct, then that is your answer.....
The gauge is grounded thru the metal cluster housing. There's only a +12 volt connection and a signal (from the distributor (-) ) connection...
Coppertop is offline
This Thread is more than 1834 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
