Crazy Electrical Grimlin - Chevelle Tech
post #1 of 7 (permalink) Old May 14th, 14, 5:55 PM Thread Starter
I was driving home in my 68 SS from the car show Saturday and got caught in a rain storm, that doesn't happen to often, so this is the 2nd time I had to use the wipers. Last time I didn't have to use my lights, this time I had lights on.
Ok, so lights are on and I turn wipers on low, the turn indicators on the dash glow green and the fuel gauge goes from 1/2 tank to 1/4 tank. If I turn the wipers to high the glow on the turn indicators goes out but the fuel gauge goes to empty. Turn the wiper off gas gauge returns to 1/2 tank.
Lights work as they should and has no effect on gas gauge or turn signals under normal operation with high or low beams. Wipers work as they should and also have no effect on gas gauge or turn indicators when the headlights are off.
Not knowing how all these systems tie into each other has got me rather stumped. Must be a ground issue because I think a test check on the gas gauge is to ground it and it shoud read empty, not sure though.
Any help would be greatly appreciated.
NVSS is offline
post #2 of 7 (permalink) Old May 14th, 14, 6:02 PM
WILD72 is offline
post #3 of 7 (permalink) Old May 14th, 14, 6:11 PM Thread Starter
Re: Crazy Electrical Grimlin
I don't have a gas gauge problem it works very well without the combo of lights and wipers being used.
BTW I had a 1/2 tank of gas and the gauge read 1/2 tank forgot to put that in my first post. Problem is how can wipers used with headlights have an effect on gas gauge?
NVSS is offline
post #4 of 7 (permalink) Old May 14th, 14, 6:28 PM
Rich
I had a similar problem on a '64 A-body Pontiac. When I stepped on the brakes, the gas gauge dropped to empty. When I turned on a turn signal, the radio turned on and off. The car ran fine other than the wierd electrical stuff. It turned out to be the ignition switch located down at the base of the column. When the switch was in the "run" position, the contacts were mis-aligned. Something that you might want to check.
Rich
Big White is offline
post #5 of 7 (permalink) Old May 14th, 14, 6:55 PM
Definitely sounds like a grounding issue. With the lights off, the lack of proper grounds isn't apparent as devices seeking a ground find it via dash bulbs thru their filaments to ground. This "path" is lost when the lights are turned on.
You need to verify the wiper switch ground strap is in place and tight on both ends. The cluster assembly needs a good ground as well. A simple method to grounding is run an 18 gauge wire from the metal cluster that holds the gauge assemblies to the parking brake bracket. Dash cluster to ground, dash frame to ground and things like wiper switch ground to dash frame for proper integrity.
Coppertop is offline
post #6 of 7 (permalink) Old May 15th, 14, 9:17 AM Thread Starter
Thanks Coppertop..........this sound like a plan.
NVSS is offline
post #7 of 7 (permalink) Old May 15th, 14, 11:26 AM
Steamy
Here's a pic of the headlight/wiper switch grounding plate and the wire that goes from the dash to the parking brake cable bracket. Be sure all this stuff is clean & tight.
Here's a pic of the lighter/ignition switch grounding ring, same conditions as above apply.
Parking brake grounding point.
BillL
My Showroom
Ark68SS is offline
This Thread is more than 2157 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
