how to check voltage to the coil - Chevelle Tech
post #1 of 7 (permalink) Old May 10th, 14, 9:29 PM Thread Starter
How do I check voltage to the HEI coil when the engine is running? remove the dust cover and go from the red wire to ground?
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #2 of 7 (permalink) Old May 10th, 14, 11:09 PM
Re: how to check voltage to the coil
You can go through the back of the connector with the red probe and clip the black one to ground.
oldcutlass is offline
post #3 of 7 (permalink) Old May 10th, 14, 11:43 PM Thread Starter
I can't because I'm using these kind of spade connectors, That's why I asked if I can remove the dust cover to check
-Super T10 2.64
-Dana 60 3.54 Posi
post #4 of 7 (permalink) Old May 10th, 14, 11:59 PM
How about making an extension with a pigtail.
post #5 of 7 (permalink) Old May 11th, 14, 2:02 AM
Sure, that'll work. You'll want to see nearly alternator voltage when the engine is running.
In other words, if the alternator is producing 14.2 volts, you'll be looking for 13+ volts at the distributor B+ connector.
Schurkey is offline
post #6 of 7 (permalink) Old May 11th, 14, 10:37 AM Thread Starter
how do I check the alternator voltage at the battery?
-Super T10 2.64
-Dana 60 3.54 Posi
post #7 of 7 (permalink) Old May 14th, 14, 8:03 PM
Positive test lead from voltmeter on positive terminal of battery.
Negative test lead from voltmeter on negative terminal of battery.
You should see 13.8 - 14.2 volt ideally with the engine running. This is your charging voltage.
Coppertop is offline
This Thread is more than 1866 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
