1964 Chevelle SS - Chevelle Tech
post #1 of 7 (permalink) Old May 10th, 14, 5:01 PM Thread Starter
grr
1964 Chevelle SS
1964 Chevelle SS
Does anyone have a wiring diagram for a 64 SS with tach and clock they can pass off to me?
My tach has 2 wires - One went to the ign fused terminal and the other wire was cut and dangling. Anyone know where that goes?
Probably more to come later....
Thanks in advance....Gary
grr456 is offline
post #2 of 7 (permalink) Old May 10th, 14, 6:16 PM
Re: 1964 Chevelle SS
The tach needs power and a signal from the distributor. The tach signal wire connects to the coil (-).
Black with pink stripe is the switched +12 volts from the ignition switch.
The tach gets its ground from the cluster it's mounted in.
Clock gets constant battery power from the black with orange stripe. It gets its ground from the cluster it is mounted in.
Coppertop is offline
post #3 of 7 (permalink) Old May 10th, 14, 8:00 PM
chelsea
If anyone has a picture I would love to see it! I'm having the same issues
redoctober64 is offline
post #4 of 7 (permalink) Old May 11th, 14, 7:16 AM
Thomas
Gary you have email. Chelsea, I did not find your email. There are 2 64 chevelle wiring diagrams. I don`t think they have the tach, but should help some.
Carolina Chevelle Association
TC # 688
ACES 2759
PeachState Chevelles
66 malibu wagon, 327, AC, pw.
67 chevelle 300 deluxe post, LT1-4L60E, 3:36-10 bolt posi,AC,tilt,pw,pl, Autometer gauges,custom dash
67 300 Deluxe, factory AC, project
"I think we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious."
--Thomas Jefferson, letter to William Ludlow, 1824
elcamino66 is offline
post #5 of 7 (permalink) Old May 11th, 14, 7:52 AM
Marcus
Here a wiring diagram but it hasnt tach. http://documents.clubexpress.com/doc...qn0RnjN0OpzeR8
Marcus
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #6 of 7 (permalink) Old May 11th, 14, 12:12 PM Thread Starter
grr
Thanks a bunch guys. This helps a lot...
I've pulled the harness out to look at it and check the wiring and it looks pretty good to me. No frayed wires and a few loose light terminals, which I'll fix.
This is probably a novice question, but I did do a search and I have done quite a few re-wire jobs, but how do you separate the fuse box from the bulkhead fittings? They normally come apart kinda easily, but not this one. I don't want to tug too hard on it since I don't want to break anything. The brake booster is making it hard to get at the bulkhead connectors. The previous owner has zip ties around the bulkhead fittings in the engine compartment.
My questions are...Did there used to be clips to hold everything together and the PO used zip ties to fix it after he broke them off? Do the bulkhead connectors pull thru to the interior of the car, or do you need to separate them from the engine compartment?
The tach has the two terminals in the back. The power (Black/Pink) went to the upper terminal on the tach. Does anyone know if this is correct?
I have attached some pics....
Thanks again.....Gary
ID:	170474   Click image for larger version
ID:	170482   Click image for larger version
ID:	170490   Click image for larger version
grr456 is offline
post #7 of 7 (permalink) Old May 13th, 14, 1:30 AM
chelsea
Thank you
This Thread is more than 1929 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
