wiper switch issues? - Chevelle Tech
post #1 of 4 (permalink) Old May 9th, 14, 2:54 PM Thread Starter
Ken
I have a 71 convertible I bought with serious wiring issues - so I have no idea what worked or didn't prior to me owning it.
I just finished rewiring my 71 with an american auto wire harness.
No issues there.
However - the wiper switch is giving me grief - I think - unless it is a ground issue?
the wiper motor only works when the button is depressed to make the squirters work - then they run for the 3-4 wipes and park
There is nothing in the on low speed or high speed functions - not even a shudder
Could this be a gound issue or is it the switch gone bad.
The AAW instructions say the three wires to the switch are actually grounds - there is not live 12V that actually goes to the switch.
The SS Gauge panel does have the ground strap from headlight switch to wiper switch - but I don't see anything other than the strap being screwed to the steel dash support bracket. Does there need to be an actual wired ground from the ground strap to the chassis/body? I would have thought that having the dash bracket bolted to the body would be ground enough?
Thoughts
Ken
seeker1056 is offline
post #2 of 4 (permalink) Old May 9th, 14, 3:34 PM
AKA Zombietroll
Re: wiper switch issues?
I can't tell you what's wrong but from experience with older cars and my 64 its usually a grounding problem. Usually you will have one power to the motor that's fused with a 20 amp and the rest are wires that go to ground.
zombie1969 is offline
post #3 of 4 (permalink) Old May 9th, 14, 4:36 PM
Make sure the switch is grounded well. I have seen wiper switches with excess play that just will not work right. Even after taking them apart cleaning and reassembly. Also the ground strap will need a clean metal surface to get a good ground. On the 65s ONE screw is all that holds the groung strap to the metal dash opening. I have seen some people make a separate ground wire and attach it between the strap and the firewall. You want clean metal to get a good ground. I recently fixed a Camaro where all the grounds were not clean. They had a high build of paint. This car was backfeeding power all over the place.
65 Malibu SS Red On Red 4 Speed
Sold It
Showroom
Current Evening Orchid Project Finally Done
eyewanta65 is offline
post #4 of 4 (permalink) Old May 9th, 14, 7:11 PM
It's absolutely critical you have the wiper switch/headlight switch ground strap assembly in place. The 2 holes represent where the screws go thru to both physically hold the switch ears in place as well as transfer the ground.
No good ground at wiper switch housing=no wipers PERIOD.
Coppertop is offline
This Thread is more than 2219 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
