Weird grounding block bolted to firewall - Page 3 - Chevelle Tech
post #31 of 38 (permalink) Old May 8th, 14, 9:54 PM
Darren
Re: Weird grounding block bolted to firewall
And, as mentioned before (donít do it yet) seal up all those gaping holes in the firewall and ISOLATE any wires running through the firewall with the correct sized grommet. This process takes forethought, as Joe said.. HAVE A PLANÖ getting a grommet in place when you are DONE is not fun, because to do it correctly, youíll have to redo it all.
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
post #32 of 38 (permalink) Old May 8th, 14, 10:24 PM Thread Starter
Thanks for the advice 70, I am getting ready to do headers and engine/engine bay repaint so when I have everything sanded down I will have all the non OEM holes filled in with metal the right way before I paint.
Bikebro is offline
post #33 of 38 (permalink) Old May 8th, 14, 10:26 PM Thread Starter
Any info on that wire that plugs into the distributor? What is its function?
Bikebro is offline
post #34 of 38 (permalink) Old May 8th, 14, 10:45 PM Thread Starter
And volt gauges seem to be the way to go over amme. huh? I might as well just replace the whole cluster then. How can I remove the oil pressure line and block it off till I install new gauges? I dont want the thing pumping oil into the cab ...
Bikebro is offline
post #35 of 38 (permalink) Old May 9th, 14, 3:51 PM
Hal
I had a similar spaghetti wiring issue on my 68'. I'd follow one red wire back and it would be spliced 5 different times, in all different colored wires, till it came to the correct wire color at the firewall. Awful what a hacked up wiring job can do. From there, it's a matter of following it to the fuse to see what the heck it's supposed to be for.
Take one wire at a time and follow it back to the fuse box or other origin. It helps to have the correct year / car wiring diagram to figure out where these wires are supposed to go. Once the basic wiring is done (lights, charging, etc.), move onto the aftermarket wiring. You may be able to find wiring diagrams for the aftermarket gauges at the manufacturer's website.
The kid next door challenged me to a water fight. Just waiting for the water to boil...
Sarcasticshrub is offline
post #36 of 38 (permalink) Old May 9th, 14, 7:27 PM
Looking at your pictures you have an HEI distributor. There are two connections under the tab that sticks out--"BAT" and "TAC".
BAT is 12 volts input that is switched from the ignition switch. TAC is where the tachometer feed connects.
I would think it would be best to plug the oil sender at the engine. Remove the sender and install an electric sender, even if it is just to plug the hole. Don't try to cap the tube running into the passenger compartment.
Coppertop is offline
post #37 of 38 (permalink) Old May 9th, 14, 7:30 PM
todd
If you're talking about the one at your finger and thumb....I believe that would be your 12 volt ignition wire. See where it is hooked up under the dash. It should go to switched 12 volt power. Someone please correct me if I'm wrong. On my 69, there is a nice lug in the fuse box for it.
todztoyz is offline
post #38 of 38 (permalink) Old May 9th, 14, 7:35 PM
Beat ya to it Todd
This Thread is more than 2209 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
