Clk ltr fuse - Chevelle Tech
post #1 of 13 (permalink) Old May 5th, 14, 6:30 PM Thread Starter
Clk ltr fuse
Keeps blowing...it was working with no prob, then just blew...sny suggestions? Click image for larger version
Name:	ImageUploadedByAG Free1399328981.855625.jpg
ID:	168953Click image for larger version
Name:	ImageUploadedByAG Free1399329000.852787.jpg
GRUSTLE is offline
post #2 of 13 (permalink) Old May 5th, 14, 7:45 PM
Re: Clk ltr fuse
What does the red wire feed connected to the "BAT" terminal?....obviously that isn't a factory connection, so that would be an immediate possible suspect.
Coppertop is offline
post #3 of 13 (permalink) Old May 5th, 14, 7:52 PM
Re: Clk ltr fuse
Did you plug anything in the cig lighter?
oldcutlass is offline
post #4 of 13 (permalink) Old May 5th, 14, 9:43 PM Thread Starter
Re: Clk ltr fuse
Nope, all i have is GV Overdrive, stereo, vacuum thingamabob for brake booster (pretty sure thats the technical term) cig lighter never worked. Everything else did at one point
GRUSTLE is offline
post #5 of 13 (permalink) Old May 6th, 14, 7:28 PM
Re: Clk ltr fuse
So what happens when you remove the red wire from the "BAT" slot and install a new fuse in the courtesy aka clock/lighter position??
post #6 of 13 (permalink) Old May 6th, 14, 8:32 PM Thread Starter
Re: Clk ltr fuse
It blows again, cig lighter is not hooked up, and i took dome light out....is it possible that alternator has something to do with it, generator light blinks at times... I checked battery, voltage is good. Alt belt does not appear to be loose...
GRUSTLE is offline
post #7 of 13 (permalink) Old May 6th, 14, 8:50 PM
Shane
Re: Clk ltr fuse
Do you have a factory clock?
fishhead is offline
post #8 of 13 (permalink) Old May 6th, 14, 8:52 PM Thread Starter
Re: Clk ltr fuse
Idk what i just did, but now i have radio and no dome light... Afraid to put it back in....id rather have radio for now... Guess we will see what it does on the way to work in the morn... Oh yeah radio is with car off so again we will see in the morn
GRUSTLE is offline
post #9 of 13 (permalink) Old May 6th, 14, 8:54 PM Thread Starter
Re: Clk ltr fuse
No factory clock... Its one of those custom autosound radios Click image for larger version
Name:	ImageUploadedByAG Free1399424054.998796.jpg
GRUSTLE is offline
post #10 of 13 (permalink) Old May 6th, 14, 9:01 PM
Shane
Re: Clk ltr fuse
Did you put a fuse back in?
fishhead is offline
post #11 of 13 (permalink) Old May 6th, 14, 9:05 PM Thread Starter
Re: Clk ltr fuse
Yeah its in... Lol with my luck im sure something will happen again... Im SOOO new to all this car stuff so this will probably be yet another crash course in something
GRUSTLE is offline
post #12 of 13 (permalink) Old May 6th, 14, 9:11 PM
Shane
Re: Clk ltr fuse
lol hang in there... it all gets figured out.
I had a wire break off the back of my drivers door interior light button. took me a few days to figure that one out.
fishhead is offline
post #13 of 13 (permalink) Old May 6th, 14, 9:54 PM
Re: Clk ltr fuse
For reference, here are factory original items originally fed from the courtesy fuse (if so equipped):
Dome light
Courtesy lights (under-dash, rear of console)
Trunk light
Clock
Cigarette lighter
Glove box light
...and anything that is plugged in the "bat" (battery power) slot on fuse block
This Thread is more than 2223 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
