Should I use a Internal regulator or not? - Chevelle Tech
post #1 of 6 (permalink) Old May 4th, 14, 6:04 PM Thread Starter
Curt
I have a 65 Chevelle and I am having a guy rebuild a 327 that was not with the car. I am putting in the 327 with no existing parts and I am starting from scratch. Should I buy a internal regulated alternator or use the existing regulator? I bought a Engine harness from American Autowire but nothing is labeled and the Black/white and dark blue wires from the voltage regulator are not in this harness, but I found them on the old harness still in the car tied up and taped. The old regulator is in the car. Any input is appreciated.
65conv is offline
post #2 of 6 (permalink) Old May 4th, 14, 6:51 PM
Devin
Re: Should I use a Internal regulator or not?
If you have to buy an alternator regardless, I'd go with a 1 wire, internally regulated.
We just went through this with my son's 65, but he already had a good alternator for external regulator, but no reg so we got one for him from RockAuto for about $10.
Either will work, but if you have nothing, the 1 wire is easier to set up.
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #3 of 6 (permalink) Old May 4th, 14, 7:05 PM
"Wild Bill"
If you decide on using an EXTERNAL regulated alternator...install a WELLS VR715 regulator.
A solid state regulator...much more stable and reliable...and if you're looking to keep a stock look, will even accept an original points type reg cover.
The VR715 costs about $18. AutoZone and others stock it.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #4 of 6 (permalink) Old May 4th, 14, 7:23 PM
If you plan to install a lot of electrical equipment that requires big power, then upgrade to a higher output internally regulated alternator. If not, then use the externally regulated one with the abovementioned solid state regulator. That is what my car has and it works well.
JWagner is offline
post #5 of 6 (permalink) Old May 5th, 14, 10:57 AM
Donny
There reason the regulator wires were not in your new harness is that they are part of the front lamp harness, not the engine harness which you have mentioned purchasing. We can set up the front light harness either way, stock or internal. If we can be of help, let us know sir.
Donny
aawtech is offline
post #6 of 6 (permalink) Old May 5th, 14, 8:14 PM
Curt,
Sounds like you just have to decide based on your wants and the needs of the vehicle's set-up.
Coppertop is offline
This Thread is more than 1997 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
