trunk light popping fuse - Chevelle Tech
post #1 of 6 (permalink) Old May 3rd, 14, 4:07 PM Thread Starter
hey guys, having an electrical issue on my 70 that maybe you can give me a good starting point.
when I plug in my trunk light into the harness and open the door my fuse pops killing my dome light and under dash courtesy lights. I understand they are all on the same circuit but not sure if I have a grounding issue and where. with the trunk light not plugged in I have no issues. all my wiring is new, including trunk harness and I even bought a new trunk light incase it was my original causing the short. all of my rear lights work fine.
Thoughts on which ground could be causing the issue?
thanks
TC Member # 5462
70 Chevelle SS/396 4-Speed
DYNO RWHP: 364HP @ 5200 RPM / 426 Torque @ 3500 RPM
Birddog1970 is offline
post #2 of 6 (permalink) Old May 3rd, 14, 4:46 PM
Re: trunk light popping fuse
Sounds like the trunk light power wire is going straight to ground. It could also be in the light socket itself. Hopefully you have a multi-meter. I'd check ohms from the bulb socket to ground first.
Alan F is offline
post #3 of 6 (permalink) Old May 3rd, 14, 6:16 PM
thanks
Dave,
I'm a little confused. You say when you open the door, the courtesy fuse pops. Do you mean the door or the trunk lid?
If opening the car door causes this, there might be more to it.
The trunk lamp only connects to the orange feed (hot all the time). The ground is provided by the trunk hinges to the body. The doors provide a ground on the white wires that ground all courtesy lights when they then open. I'm wondering if if there is a connector issue or moving a wire causing issues. By right, if there was a problem with the trunk light, you'd blow the courtesy fuse immediately when connecting it to orange power.
What happens when you connect the trunk lamp to the orange courtesy feed and touch the housing to a good ground, does it light, or does it blow out the fuse? Remember you have to tilt it to mimic it's "on" position like when it's mounted in the trunk lid as it uses a mercury tilt switch.
Coppertop is offline
post #4 of 6 (permalink) Old May 3rd, 14, 8:18 PM Thread Starter
Joe, good questions. I'll have to double check the sequence when the fuse pops. believe with the trunk lid closed and when I open the car door or pops, but if I have the trunk light wire disconnected from the harness no issues.
I'll pull the light and try to touch it to a good ground source in the correct position with doors closed to see what it does.
thanks,
TC Member # 5462
post #5 of 6 (permalink) Old May 3rd, 14, 8:22 PM
Check bulb in trunk light to make sure it is a single pin and not a duel pin. Just a thought.
25C 70 is offline
post #6 of 6 (permalink) Old May 4th, 14, 10:24 AM
blm
Dave: Is this something that just started happening or has this been the issue since the new wiring? Sounds like this is just the courtesy circuit and not related to the other lights in the rear. Unless it is something obvious a multimeter will find the problem. They are a great troubleshooting tool and will help one to keep their sanity. Very easy to use once one understands how they work and what they are looking for.
blm is online now
This Thread is more than 2157 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
