Under dash A/C blower motor added a relay - Chevelle Tech
post #1 of 10 (permalink) Old May 2nd, 14, 8:57 PM Thread Starter
JKK
JK
My under dash A/C blower motor was only getting 11.2 volts installed a relay with power coming from the horn relay now getting 12.8 volts blows twice as hard on high as it did before
JKK is offline
post #2 of 10 (permalink) Old May 2nd, 14, 10:00 PM
Re: Under dash A/C blower motor added a relay
Under-dash A/C blower?
Is this an aftermarket set-up?
Coppertop is offline
post #3 of 10 (permalink) Old May 3rd, 14, 3:35 AM Thread Starter
JKK
JK
Yeah it's a Vintage Air system
JKK is offline
post #4 of 10 (permalink) Old May 3rd, 14, 7:25 AM
Dennis
Can anyone explain to me like I am 5, Why this works this way ?
Deisel23 is offline
post #5 of 10 (permalink) Old May 3rd, 14, 9:24 AM
Same process at having VERY bright headlights. My 70 Wagon and most all other Chevelles have, Not so bright headlights and dash lights.
Using relays, The headlights on my 70 are now 30-40% brighter and I now use the dimmer switch on the dash lights.
To take advantage of a 12 volt Batt. Make sure your, Lights, and all Accs. are getting 12 volts, 9-10-11 volts will make it operate, BUT not as good as 12 Vts.
Could that be the reason ALL modern cars/trucks use " RELAYS " ?????
Robinls5 is offline
post #6 of 10 (permalink) Old May 3rd, 14, 6:29 PM
The problem is, most people end up using relays as a 'crutch'. Instead of solving why there is a low voltage situation.
For example, 12.8 volts at the horn relay with the engine running is too low and indicates there are wiring/charging issues.
Bob--
The reason modern vehicles use so many relays is the controls on virtually item is dictated by the BCM, PCM etc. These modules are only capable on sinking or sourcing (providing a ground or positive out) a small amount of current that could not "drive" things like lamps, starter solenoids, fans, etc. They can however, drive relay coils directly, and of course the relays do the "heavy lifting" to provide the large current paths to the vehicle devices.
post #7 of 10 (permalink) Old May 5th, 14, 1:34 PM
Dennis
Bob--
So, through a relay it takes less amount of current to drive say a headlight, than if it were wired directly without a relay ? Is that it ?
Deisel23 is offline
post #8 of 10 (permalink) Old May 5th, 14, 7:56 PM
Dennis,
A relay is basically an electric switch. Contacts inside are operated by an electromagnet. The coil of wire inside a relay doesn't draw very much current at all. What ever your are controlling (fan, headlights, etc) still draw the same amount of current, the relay just takes the "burden" off a control switch or circuit.
Think of it like this, you could use a tiny toggle switch to turn on your headlights. If you tried to run the headlights directly thru the tiny toggle, it would quickly burn-up due to all the current the headlamps are pulling. By simply using the toggle to trigger a relay coil, the tiny amount of current for the coil is no problem for the toggle. In turn, the relay's contacts control the high current to actually feed the headlamps.
You would also need to run a new circuit or modify an existing one (the main power feed) to supply the relay's contacts and ultimately to the headlamps.
post #9 of 10 (permalink) Old May 6th, 14, 7:42 AM
Dennis
Dennis,
Thanks for the info. I have to be honest, I understand that it's a remote switch...I just don't know the difference between that relay, and the headlight switch. I don't get how that benefits the system. And I don't think I need to at this point, I just need to accept that it does, and wire my stuff accordingly.
Deisel23 is offline
post #10 of 10 (permalink) Old May 6th, 14, 7:34 PM
Dennis, the headlamp switch and a relay perform the same task--complete a higher current circuit. By using the relay (and new related wiring to connect everything) you take the burden off of the main power wire in the dash that used to provide all the current to the lights in addition to all of the dash controls and the rest of the car.
It's not just the relay, it's the relay being used to control a new circuit dedicated to whatever load you desire so the burden is taken off of the original circuit.
This Thread is more than 1869 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
