1972 horn relay - Chevelle Tech
post #1 of 3 (permalink) Old May 2nd, 14, 8:36 PM Thread Starter
Duane
Thumbs down 1972 horn relay
I put a post on here last week but it appears to be gone.anyway a wire that runs from the horn relay down through the firewall burnt when I tried to start the car.nothing happened at the starter.the interior lights went out.its a 72 chevelle.can anyone tell me what's going on.do I have a bad relay or starter maybe.it was working fine before that. I am lost
blackbear62 is offline
post #2 of 3 (permalink) Old May 2nd, 14, 8:50 PM
Re: 1972 horn relay
Was your post here in Electrical? I don't remember seeing it. Regardless....
Sounds like you fried your fusible link that protects the interior of the car. When this blows, all power is lost to interior, dash and dash-fed circuits (headlights, tail lights, starter).
You need to determine why it blew. One scenario is the purple wire that that "triggers" the "S" terminal on the starter solenoid got melted on the hot exhaust manifolds or headers, and then got shorted to ground. The next time you went to start the car, you sent 12 volts directly to ground (dead short) and the fusible link burned to protect the car from fire.
Do you still have 12 volts at the threaded stud on the horn relay where all the wires "bolt" together?
Coppertop is offline
post #3 of 3 (permalink) Old May 2nd, 14, 8:59 PM Thread Starter
Duane
Re: 1972 horn relay
All the interior lights come back on when I let go of the key but the wire I was talking about is soft now.i will have to check the purple wire
This Thread is more than 2169 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
