Clock in console won't light up - Chevelle Tech
post #1 of 3 (permalink) Old Apr 29th, 14, 1:07 PM Thread Starter
Rory
Hi, on the 67 Chevelle I bought recently the clock in the console doesn't light up when you pull on the lights at night. I tried the replace the bulb but the old burned out bulb was melted into the light socket. I removed it and cleaned it up but I can't get a new bulb to light up.
In order to fix this do I need to order a new wiring harness for inside the console so I have a new bulb socket to plug the new bulb into?
I was also thinking about possibly ordering a new quartz clock for the console. If I do that, I'm assuming it comes ready to just plug into the existing wiring harness right? That should already have the new bulb and everything inside of it so maybe that's the best/easiest way to go and just plug it in. Any thoughts, advice or help would be greatly appreciated! Thanks!!
Rory67SS396 is offline
post #2 of 3 (permalink) Old Apr 29th, 14, 9:30 PM
Re: Clock in console won't light up
The bulb pigtails are separate from the clock mechanism. Buying a new clock would not ensure you get a new lamp pigtail/holder. You might be able to find a pigtail in the aftermarket at a parts store if yours is damaged. Did you take a test light to verify the gray wire has 12 volts with the headlights on?
The bulb holder gets its ground from the clock body which ultimately gets a ground from the car body thru it's mounting.
Coppertop is offline
post #3 of 3 (permalink) Old Apr 29th, 14, 9:44 PM Thread Starter
Rory
Thanks Joe, I'll be getting the car out of a storage facility this coming Sunday so I'll have to get a test light to see if there's juice getting through the wire with the lights on. I'll let you know what I find out. Thanks, Rory
This Thread is more than 2261 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
