69 which wire powers up the fuse block??? - Chevelle Tech
post #1 of 9 (permalink) Old Apr 27th, 14, 8:39 PM Thread Starter
i have a 69 chevelle and it had a battery in the trunk when i bought it, everything just not corectly, so i moved the battery back up front, hooked every thing up and still not right the problem is headlights,domelights,and flashers wont work till you turn ignition on!! with the ignition off the turn signals do work, goofy right, this car does not use a voltage regulator either, i have a 1 wire alt on it connected directly to the battery and a modern msd elctronic ignition, i think i need to know what wire powers up the fuse block corectly, then hopefully i can figure the rest out
85 CORVETTE<br />BEST 1/4 NUMBERS:<br />60FT 1.41 1/8 6.52 1/4 10.27 AT 131.63THROUGH THE MUFFLERS ALL MOTOR FULL WEIGHT 3300lb 3.07 GEAR CAR AS OF 10-15-04
sbchevy is offline
post #2 of 9 (permalink) Old Apr 27th, 14, 9:15 PM
Re: 69 which wire powers up the fuse block???
Sounds like someone did a real hack- job.
In factory form, a red 12 ga. wire feeds the entire interior. It enters the bulkhead connector at the firewall on the far driver's side of the connector assembly apart of the forward lamp harness.
The other end is spliced to a 16 ga. black fusible link wire which is connected to the horn relay, which in turns get battery power from a 10 ga. red that runs in front of the radiator to the battery + junction block behind the battery.
Coppertop is offline
post #3 of 9 (permalink) Old Apr 27th, 14, 9:18 PM
Originally the fuseable link from the positive battery cable fed the single terminal on the core support behind the passenger's side headlight, then fed from there across under the radiator top plate to the "BAT" terminal on the horn relay, then onto the bulkhead connector.
post #4 of 9 (permalink) Old Apr 28th, 14, 10:18 AM
Vince
hopefully the fuse block wiring was not modified also...
draw your power wires on a diagram so you can refer to them in the future.
need to figure out what/how the previous owner changed the wiring when moving the
battery to rear, i've modified alot of my original harness to make it work how i want.
but i'm still using the fusible links to protect the system same as factory
VinceS427bb is online now
post #5 of 9 (permalink) Old Apr 28th, 14, 8:42 PM Thread Starter
thanks guys, i think i have a handle on it now, thanks again!!
sbchevy is offline
post #6 of 9 (permalink) Old Apr 29th, 14, 4:31 AM
Sergio
Get yourself a factory assembly manual. That thing has helped me out big time in the electrical department.
Delta is offline
post #7 of 9 (permalink) Old Apr 29th, 14, 10:18 AM
Rob
is the 69 wiring color coding the same as a 68? I just picked up a 68 with the same issue and am trying to trace all the headache. I have a Haynes Manual for now starting at 69.
djweaz is offline
post #8 of 9 (permalink) Old Apr 29th, 14, 12:09 PM
Well the ignition is different so I doubt it.
For 20 bucks you can get a 68 diagram from classiccarwiring though.
http://www.ebay.com/itm/1968-68-Chev...727ff5&vxp=mtr
post #9 of 9 (permalink) Old Apr 30th, 14, 9:15 AM
Sam
The 69 and 68 are different in other ways. I also had the 69 diagram and was also trying to trouble shoot a 68 but there are some subtle differences.
Mine is too old to scan... maybe someone else here has the 68
boomer is offline
This Thread is more than 2265 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
