68 Fuse Box issues - Chevelle Tech
post #1 of 6 (permalink) Old Apr 25th, 14, 2:00 PM Thread Starter
Sam
68 Fuse Box issues
Anyone had issues with just one or two of their circuits of the Fuse Box. My bottom right 2 circuits (switched) have power going in but not out. Fuses have been tested and are good.
New wiring harness for Engine side, using existing for cabin side. Tested and power going in and power coming from the ignition
Before I pulled the fuse block out and looked behind it I was curious to know if anyone else had a similar issues.
thanks in advance
boomer is offline
post #2 of 6 (permalink) Old Apr 25th, 14, 6:10 PM
Vince
Re: 68 Fuse Box issues
could be a broken or corroded spade terminal , melted-damaged connector on firewall engine side of assembly
VinceS427bb is offline
post #3 of 6 (permalink) Old Apr 25th, 14, 10:20 PM
thanks in advance
Don't take everything apart until you try the basics.
Take some fine emery cloth or very find sand paper and clean away any oxidation and corrosion on the inside of the fuse block clips. The curved areas that grasp the end barrels of the fuse need a good clean contact or you typically get what you are experiencing.
Coppertop is offline
post #4 of 6 (permalink) Old Apr 26th, 14, 7:56 AM
AKA Zombietroll
Are the contacts where the fuses go rusty? Mine are and cause problems all the time. I once years back used a ball tip carbide bit and cleaned it up real good. Isn't 100% but for the most part now it works.
zombie1969 is offline
post #5 of 6 (permalink) Old Apr 26th, 14, 8:22 AM
Les
Afterwards a good finish up and PM that I do is coating the contact area with WD-40.
Les Saville
Les Saville is offline
post #6 of 6 (permalink) Old Apr 26th, 14, 9:24 AM Thread Starter
Sam
Thanks for all of the great advice. I am going to tackle it this afternoon and will post what the problem was.
Regarding cleaning the contacts, I thought they were clean but now thinking about it I did not inspect. I popped the fuses in and out a couple of times as I tested them with my Ohm meter to make sure that they were good.....eyes not being what they use to be....
boomer is offline
This Thread is more than 2222 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
