70 chevelle SS396 - Chevelle Tech
post #1 of 7 (permalink) Old Apr 25th, 14, 10:53 AM Thread Starter
Richard
70 chevelle SS396
Good Morning. The car have factory gauges.
I have a problem I am trying to fix. I installed a GM HEI distributor. I have new wiring harness from M&H. I hook the wire from the tach to the distributor and the tach will not work. I installed a new circuit board and it still will not work. I hook an after market tach and it works. I would like to make my factory gauges work. I like the look a lot more then after market gauges. Any help will be a big help.
Thanks Chevelle Rock.
rarmijo is offline
post #2 of 7 (permalink) Old Apr 25th, 14, 12:24 PM
T.C.
Re: 70 chevelle SS396
Welcome Richard!
T.C.
BMR Sales is offline
post #3 of 7 (permalink) Old Apr 25th, 14, 1:18 PM
Ray
Welcome Richard to the site. You need to ask this question in the Electrical and Wiring forum.
70 SS Chevelle Van Nuys Cal Built
shadowgray396 is offline
post #4 of 7 (permalink) Old Apr 26th, 14, 11:24 AM Thread Starter
Richard
70 chevelle SS 396.
Good Morning I am Richard Armijo. Email address [email protected]
I am trying to fix my problem with my factory tach. I installed a HEI distributor and the tach will not work. I installed new wiring harness from M&H for HEI and it still won't work. If anyone has the answer it would be great. Thanks.
rarmijo is offline
post #5 of 7 (permalink) Old Apr 26th, 14, 6:05 PM
Re: 70 chevelle SS 396.
Hi Richard, welcome to TC.
If your factory tach worked properly with the old breaker points ignition before you changed to HEI, you most likely need a an HEI tach filter. This "conditions" the signal coming from the "TACH" output from the HEI before it gets to the tachometer. In the factory form, they looked like a little cylinder with an "in" and "out" wire and the body of the cylinder was grounded. Do a search for "HEI TACH FILTER".
Coppertop is offline
post #6 of 7 (permalink) Old Apr 27th, 14, 9:30 AM
Rich
Welcome to TC, Richard----
Rich
---1965 Malibu SS Ragtop 283/416 heads/700r4
---2009 Corvette Coupe
"Whatever it is, I'm against it." --Groucho Marx
richietables is offline
post #7 of 7 (permalink) Old Apr 27th, 14, 8:48 PM
Freddy
Welcome to the site.
Freddy Mercado is offline
This Thread is more than 1944 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
