Wiring an electric fuel pump - Chevelle Tech
post #1 of 7 (permalink) Old Apr 24th, 14, 7:51 AM Thread Starter
I plan to run my fuel pump from a relay. Could I use the tach signal from my MSD box to turn on the relay, as a safety measure - no RPM = no fuel pump?
'67 Elky - 496 / TH400
"Democracy is two wolves and a lamb discussing what's for dinner. Freedom is a well armed lamb contesting the vote" Benjamin Franklin
phocksphyre is offline
post #2 of 7 (permalink) Old Apr 24th, 14, 4:29 PM
Ben
Re: Wiring an electric fuel pump
how would it work for startup when the car isn't running yet?
Ben R.
RAMBO is offline
post #3 of 7 (permalink) Old Apr 24th, 14, 5:04 PM
autumngold
Always run a fuel pump safety switch,its mandatory on most tracks.Get the painless fuel pump relay and wire it into the circuit with the switch,i think the last one I hooked up was into the starter circuit.The schematic comes with the switch and relay.No oil pressure,no fuel pump.
1970 ls-5 numbers matching
marcrose is offline
post #4 of 7 (permalink) Old Apr 24th, 14, 6:39 PM Thread Starter
Carburetor.
post #5 of 7 (permalink) Old Apr 24th, 14, 6:40 PM Thread Starter
Ok. I'll take that as a 'no'. It was to be temporary, not long term.
post #6 of 7 (permalink) Old Apr 24th, 14, 7:02 PM
No. If it's an MSD 6al, the tach "out" is a digital signal, a square wave with 20% duty cycle for signal.
The "typical" set-up usually involves buying an oil pressure sender with extra contacts. With oil pressure, the contacts allow a current to flow thru a relay's coil which in turn switches power to the fuel pump.
Coppertop is offline
post #7 of 7 (permalink) Old Apr 25th, 14, 8:01 AM Thread Starter
I was looking for shortcut that would be safe for temporary use. I guess the oil pressure switch is the way to go.
This Thread is more than 2234 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
