Anyone ever tried these bulbs - Chevelle Tech
post #1 of 13 (permalink) Old Apr 23rd, 14, 2:25 AM Thread Starter
JKK
JK
1157 50 watt replacements use in tail lights
http://www.ebay.com/itm/2PC-Bright-5...r#ht_476wt_973
JKK is offline
post #2 of 13 (permalink) Old Apr 23rd, 14, 4:39 AM
Les
Re: Anyone ever tried these bulbs
I wouldn't bother. They're overpriced and shipping is crazy too!
They can be shipped 1st class for less than 3 bucks.
Someone's trying to get rich quick?
Carchisler is offline
post #3 of 13 (permalink) Old Apr 23rd, 14, 11:34 AM
using my Googlefoo powers (Google is your friend) with the search "h1157 light bulbs", I found these (and more):
http://www.1000bulbs.com/product/110...FUiFfgodhbQAEw
However, I would wonder what the heat in the lamp assembly would be, and whether it might cause issues with the plastic lens.
Good luck,
"Just remember, your last car is always a station wagon." chaos10meter, on The H.A.M.B.
chevygod is offline
post #4 of 13 (permalink) Old Apr 23rd, 14, 2:20 PM
If you want bright, I'd be looking at LED's. http://www.superbrightleds.com/morei...ed-tower-/814/
I put a pair of 1157's on my motorcycle that are >2x as bright as stock. They weren't cheap but I wanted something that was more obvious for safety.
Alan F is offline
post #5 of 13 (permalink) Old Apr 23rd, 14, 4:53 PM
That looks like a huge increase in heat. I would be thinking it could damage the lens and maybe the lamp housing. Here is some info on the ordinary 1157 lamp.
http://wiki.answers.com/Q/What_is_th..._bulb?#slide=2
JWagner is offline
post #6 of 13 (permalink) Old Apr 23rd, 14, 5:15 PM
Looking at an ad for the H1157's, it says "not for use in plastic sockets". So that definitely points to a heat issue. And lets me out of using them in many of my cars.
Alan,
Read about LED's on a cycle site, was stated that diodes were required to make them work for the person discussing. Did you need any other wiring or diodes to get them to work for you?
chevygod is offline
post #7 of 13 (permalink) Old Apr 23rd, 14, 5:28 PM
Vince
Alan,
there is a special flasher assy. led #552
VinceS427bb is offline
post #8 of 13 (permalink) Old Apr 23rd, 14, 9:17 PM
Alan,
I'm not an expert but discerned that I only needed the diodes if I was using the bulb in a flasher position. The brake and run lights don't flash so no diode needed. I did buy some aftermarket LED turn signals but they were already set up.
Alan F is offline
post #9 of 13 (permalink) Old Apr 23rd, 14, 10:04 PM
front and rear dual filament bulbs on a Chevelle do flash, so the LED's could be an issue
chevygod is offline
post #10 of 13 (permalink) Old Apr 24th, 14, 12:35 PM
Dana
To run LED, you just need a compatible electronic flasher. I have them in my 70 convertible.
70ChevelleRagtop is offline
post #11 of 13 (permalink) Old Apr 24th, 14, 1:14 PM
what you need to run LEDs in a flasher capacity is called a no load flasher. The higher-than-led current draw of a regular bulb is what causes the flasher cans to oscillate back and forth. the LEDs dont have the same draw so they never make the flashers flash. I got my no load flashers from mike at musclerodz when i picked up my animated LED tails and LED markers but they are prob quite common now and you could get them just about anywhere.
-Joe
Team Chevelle #2680
'69 Malibu Convertible
- Official Build Thread!
http://www.facebook.com/unkinjoe
joeyv69ragtop is offline
post #12 of 13 (permalink) Old Apr 24th, 14, 5:59 PM
AKA Zombietroll
Never heard flasher's called no load. I use an electronic flasher. Looks just like a standard flasher and has the same flash time no matter how many bulbs are on the circuit. Only draw back is you don't get the slow flash when a bulb is out until a cop let's you know.
zombie1969 is offline
post #13 of 13 (permalink) Old Apr 24th, 14, 6:55 PM
Well, whoever is the marketing genius behind those bulbs should be slapped.
Halogen lamps in tight quarters behind a standard lens?
No only do you risk "liquifying" your tail light lenses, the factory and aftermarket replacement sockets take a huge brunt of that heat. Those will be quickly damaged as well. That style of lamp (although not dual filament) is what we used in the older pre-LED rotators in light bars when I worked for the State Patrol as an electronics tech. Even with high temperature fiberglass wiring and special lens design--boy was there still heat damage!
Not sure where the need for "diodes" comes into play for LED replacements unless you are making your own stuff from scratch...
Coppertop is offline
This Thread is more than 1880 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
