Painless Wiring or American Autowire? - Chevelle Tech
post #1 of 14 (permalink) Old Mar 31st, 14, 4:18 PM Thread Starter
Anibal
i have to order a full car wiring harness for my 72 chevelle. i plan on doing it myself and ive never done it before, so i want something that i will have the least trouble with. i was looking at the painless kit and the American Autowire kit. i read on another thread that the AAW requires special crimmpers that are $100 a piece. Thats pretty steep for only doing this once... The Painless wiring harness i found on summit doesnt look like it has as much stuff as the AAW kit and you have to purchase a separate engine harness kit which is another $150. not sure what to do here guys im not too happy with either kit. whats your guys experience with them?
Nebogloza24 is offline
post #2 of 14 (permalink) Old Mar 31st, 14, 7:06 PM
Ron
Re: Painless Wiring or American Autowire?
You can rent the crimpers I do believe. Both are good products but there are some catches. One big one is if you have electric fans they really don't support them properly in the upgrade version...
bikeron is offline
post #3 of 14 (permalink) Old Mar 31st, 14, 7:15 PM
Jerry
Get the M&H Electrical harness from James at Hinshaws Chevelles. http://www.hinshawschevelle.com It will be plug and play, correct colors and connections. Have used several of them and they are the best in my opinion.
Jerry Briggs is offline
post #4 of 14 (permalink) Old Mar 31st, 14, 9:15 PM
jessie
My first choice would be M&H second choice American Autowire kit.
trips67chevelle is offline
post #5 of 14 (permalink) Old Apr 1st, 14, 1:25 AM
what Jerry and jessie said. but, AAW has people who logon here regularly and help with wiring issues. This is worth a fortune if you run into trouble along the way. As near as I can tell the AAW and M&H are very nearly the same stuff.
post #6 of 14 (permalink) Old Apr 1st, 14, 10:17 AM
Anyone have an opinion on Ron Francis' harness?
Jim Wamsley
1971 Chevelle SS 454
vester is offline
post #7 of 14 (permalink) Old Apr 1st, 14, 11:22 AM
Robert
This is one of those topics’ that have been brought up a lot. If you do a search you will find them. If you want good plug and play and is very close to stock AAW and M&H is the way to go. However if you like doing things and are good with wiring Painless is very nice and a good product, but it's not for the novice. I went with Painless and it was fun for me, and since my car is far from stock it was a benefit in my opinion because of the use of modern fuses and the ease of adding additions without cutting up a factory style wiring harness.
'67 Elky Global West suspension kit with coil over QA1's, 435hp Edy Crate,700R4, Currie +9 3:75, Disc brakes front and rear, Dakota Digital gauge package, 12 Circuit Painless wiring kit, Ididit tilt Colum, etc.
2012 HD Tri-Glide in Vivid Black.
1967 XR7 Cougar S code 390.
2016 Charger R/T in Purple.
rak1 is offline
post #8 of 14 (permalink) Old Apr 1st, 14, 12:31 PM
Brandon
Love my AAW harness. Good instrucitons, everything is labled, great quality product and the tech support is awesome if you need it.
71 Chevelle
ATK Engines 496 Stroker
TH400 / 9 Inch 3500 Stall
Full UMI Suspension with Viking Shocks
http://brandons71chevelle.weebly.com/
ATK HIGH PERFORMANCE ENGINES
WWW.ATKHP.COM
Need an engine...shoot me a PM.
ATK SBC Perf. Cylinder Heads are IN STOCK! 64cc/70cc - 185cc/195cc/210cc
Notalent is offline
post #9 of 14 (permalink) Old Apr 2nd, 14, 9:48 AM
Donny
As others have stated, there are two distinct paths to go down. Stock "plug-n-play", or modified.
The stock stuff we manufacture can be built with alternator or ignitions system upgrades as needed also.
The main difference between our modified (Classic Update) or and Painless, or a Ron Francis kit is the completeness. They are all good products, but our kit is far more complete. It gives you all the correct lamps sockets, terminals, and connectors that are needed to complete the entire job. You will not have to cut and splice 40-60 wires to your 40+ year old lamp sockets and connectors like you will with the other kits.
Regarding Ron's comment, our kit does in fact address electric fans. We have a dedicated fused circuit with a trigger wire to use with any relay. We just do not supply that relay kit itself with the Classic Update kit as most fan suppliers or manufacturers supply that with their fan. If we were to include a relay kit, it would increase the cost of every kit by about $25.00. We just felt that it was better to supply that item separately. If someone is building a car that does require one, we do offer a high performance fan relay kit that utilizes SXL and GXL hi-heat wire, a good relay, and an OEM Delphi-Packard base, as opposed to an inexpensive "off shore" piece.
Donny
aawtech is offline
post #10 of 14 (permalink) Old Apr 2nd, 14, 8:26 PM
Roger
I'm finishing re-wiring my 72 Elky w/ the AAW kit and love it. One of the best parts is that all the wires are labeled which really comes in handy.
I'm modifying my kit somewhat. I'm adding Digital Dakota gauges, Vintage Air, a dedicated relay system for the headlights and an upgraded stereo. But so far so good. The only issue I'm having is finding a location to mount the DD control units. But that has nothing to do w/ the AAW wiring kit.
So my recommendation is the AAW kit.
DrPepper is offline
post #11 of 14 (permalink) Old Apr 3rd, 14, 2:00 PM Thread Starter
Anibal
Thanks for the help guys. I think for me the best kit is the AAW because of its completeness. thanks again
post #12 of 14 (permalink) Old Apr 3rd, 14, 3:12 PM
I want to say that M&H sent me one hellova nice harness for my 70'. Factory colors and fittings. The fuse box was spot on for the original GM unit. It was crazy easy to install, practically fell in. Called em' once for help and they guy was very knowledgable and was not in a hurry to get off the phone.
Toddlamesa is offline
post #13 of 14 (permalink) Old Apr 3rd, 14, 3:37 PM
Bart
Why not Ron Francis? Has awesome select-a-circuit. Doesn't have bulk head connection though.
1969 Chevelle Malibu 396BB, DNE2 4speed (do not want - would sell), 12 Bolt, 18x9.5 Snettertons with 245/40 and 285/35s Conti3s.
My Build thread - https://www.chevelles.com/forums/show...958&highlight=
Wanted - 2" Cowl Hood. Would trade my 4".
barrrf is offline
post #14 of 14 (permalink) Old Apr 8th, 14, 12:05 PM
I put AAW kit in my '71 - long but easy install. Everything worked on first try. Liked the ATC fuses and adaptability for HEI, 1-wire alternators, elec fans etc. I bought the Delco crimpers as they are are worthwhile tool and provide a factory like connection.
'66 SS396 502-502; '71 SS454 Convertible
RCBach is offline
This Thread is more than 1905 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
