Wipers to park - Chevelle Tech
post #1 of 7 (permalink) Old Feb 23rd, 14, 9:27 PM Thread Starter
Wipers to park
1968 chevelle...will my wipers go to park if the washer pump is not connected?
hoopsnut is offline
post #2 of 7 (permalink) Old Feb 24th, 14, 2:16 PM
Steamy
Re: Wipers to park
Yep.
BillL
My Showroom
Ark68SS is offline
post #3 of 7 (permalink) Old Feb 24th, 14, 5:03 PM
Re: Wipers to park
Speaking of wipers in park.... I am just getting my 67 back together and I turned my wipers on and off.... we they didn't park, they just stop... How can I fix this... I would rather fix it than replace it... info?? Help?? Advice?? Thanks!!
daddio65 is offline
post #4 of 7 (permalink) Old Feb 24th, 14, 8:49 PM Thread Starter
Re: Wipers to park
First, does your wiper motor have the park feature? Have you ever seen them go to park?
hoopsnut is offline
post #5 of 7 (permalink) Old Feb 24th, 14, 8:59 PM
Re: Wipers to park
Yes, it "did" have the park feature... I just got my car back together and was going to put my wipers on... but I wanted to make sure they were in park so I didn't screw up the new paint
daddio65 is offline
post #6 of 7 (permalink) Old Feb 24th, 14, 10:40 PM Thread Starter
Re: Wipers to park
There is a small set of points that open and close that open the ground on the park circuit. That was my problem. They are located under the washer pump inside. There is a small 1/8 inch hole just above the ground strap in the pic. The points can be seen through this hole. Just make it a bit larger and you can clean the points up.
hoopsnut is offline
post #7 of 7 (permalink) Old Feb 25th, 14, 9:38 AM
Re: Wipers to park
Thanks a ton, I will get it fixed asap!!!
daddio65 is offline
This Thread is more than 2110 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
