Battery Disconnect switch? - Chevelle Tech
post #1 of 14 (permalink) Old Feb 20th, 14, 5:26 PM Thread Starter
Chas
Anybody using one of these battery disconnect switch. I thought it would be handy to disconnect my battery. But the dang thing falls apart when you remove the Green connectivity screw? Any body else have this issue?
Name:	batt switch.jpg
Chas
My car:
"The past is gone. The future may never see a car like this. It is one of the brutes, and all it needs is a way of staying in contact with terra firma" Hot Rod Magazine, May 1970.
Chevy 70 SS vert is offline
post #2 of 14 (permalink) Old Feb 20th, 14, 6:47 PM
RonO.
Re: Battery Disconnect switch?
Chas, why are you using this in the first place? I am familiar with this item, wondering how it benefits you?
1970 Chevelle 517 cid, TH400, best ET mid 9's. #19.
70SSTHUMPER is offline
post #3 of 14 (permalink) Old Feb 20th, 14, 6:56 PM
Fat Stig
I've got one on the Buick. I think it was installed there by the PO as a cheap fix for a slow battery drain.
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
I have to keep reminding myself this isn't a Z16 convertible, Evening Orchid Camaro, or factory 1966 SS427 and get on with it.
Andy69 is offline
post #4 of 14 (permalink) Old Feb 20th, 14, 8:25 PM
Frank
Yes, I use one on my 65 and I like the fact that it does as you say "fall apart". When I park the car I just unscrew the green knob and take it with me. The battery is now disconnected from the starter and it becomes a anti-theft device.
ID:	149473   Click image for larger version
1965 Malibu SS coupe ... 327ci, 4 speed, 3.73 posi
Driving a musclecar, "PRICELESS"
MalibuSeaS is offline
post #5 of 14 (permalink) Old Feb 20th, 14, 10:46 PM
Art
Send a message via Yahoo to z06 vette
I have used one and it works a disconnect of the battery. I had no problems and they are cheap.
z06 vette is offline
post #6 of 14 (permalink) Old Feb 20th, 14, 10:56 PM
Steamy
Wink Re: Battery Disconnect switch?
I wouldn't use one. The contact area of that switch is too small for heavy loads. Les Saville's '67 GTO damn near caught on fire while he was driving it due to the negative battery cable melting.
Carry a pair of pliers if you have the spring ring battery ends, or a wrench for the bolt on ends to remove the cable. It ain't that hard to do and a lot safer.
BillL
My Showroom
Ark68SS is offline
post #7 of 14 (permalink) Old Feb 21st, 14, 12:14 AM Thread Starter
Chas
Yes my thoughts exactly!
Chas
My car:
post #8 of 14 (permalink) Old Feb 21st, 14, 12:16 AM Thread Starter
Chas
BillL
I think thats a great idea as well!
Chas
My car:
post #9 of 14 (permalink) Old Feb 21st, 14, 12:19 AM Thread Starter
Chas
On my other collector car I have a different battery disconnect switch and I have managed to get extended life out of the battery (7 years plus) by doing this whenever it isn't driven. Plus it serves as an anti-theft device as well. :-)
Chas
My car:
post #10 of 14 (permalink) Old Feb 21st, 14, 11:13 AM
Don
I have been using the "Green Knob" disconnects for at least 15 years on all 5 of my cars. You dont have to remove the knob, just loosen it. Whenever I go a cruisenite or show, the first thing I do is open the hood and loosen the knob, even in my garage. No worries about a car fire, the only downside is the mechanical clock wont keep the time,, but at the beginning of every season, I set the clock at 12:00, and use it as a "Run Time" meter. I see these disconnects all over at swapmeets for $3-$4. and on ebay for $16. Don S
Don S
69 SS396
68 Impala SS427 x4
68 Impala L-72
impalass427 is offline
post #11 of 14 (permalink) Old Feb 21st, 14, 11:22 AM
I had one for a while but it caused my radio to loose all its presets.
What do you do about that?
post #12 of 14 (permalink) Old Feb 21st, 14, 4:15 PM
Don
Some of these green knobs are sold with a pigtail fuseholder so you can run a small wire to the aftermarket radio memory wire, or you can add one yourself. A one amp fuse should be plenty.
Don S
69 SS396
68 Impala SS427 x4
68 Impala L-72
post #13 of 14 (permalink) Old Feb 21st, 14, 4:56 PM
Claude
I had one of those green knob disconnect switches and although it did work fine, I got tired of having to open and close the hood just to turn it on whenever I wanted to go for an occasional ride in my car, and then reopen and close the hood again when I got back to disconnect the battery so I replaced it with one of these: http://www.painlesswiring.com/webcat...v.php?sl=30205. The big relay is installed under the hood and the red button inside the console. So now, all I have to do is to push or pull on the red button and I'm ready to go, no more need to open and close the hood!
Claude.
1971 Chevelle SS
toofastforyou is offline
post #14 of 14 (permalink) Old Feb 21st, 14, 11:00 PM
RonO.
Good move Claude, I used a similar kit in my 70' and it is alot easier now to disconnect. Great theft deterrent also. Small discreet button underside of dash, out of sight.
http://www.summitracing.com/parts/prf-30206/overview/
This Thread is more than 2194 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
