Newbie with 2 quick questions regarding AC wiring - Chevelle Tech
post #1 of 3 (permalink) Old Feb 19th, 14, 10:21 PM Thread Starter
Good Evening everyone- I am reaching out to you once again as i am finishing up the rewire of my entire car...I purchased the Classic Update Kit from AAW ( love it) but i did not purchase the AC harness as the car has a brand new one from another company...So here is my question...
Does the Orange wire on then engine harness that goes to the blower motor connect to the in line fuse wire from the AC harness before it enters the firewall? ( My car has factory AC - 71 Chevelle Malibu) I think that with factory AC the orange wire isnt used but i cannot figure out what other wire would possibly connect....
Second while i have your attention - the directions say to apply silicone sealant after installing terminals..What is the name of this sealant and can you buy it at any of the chain part stores? I have applied Dielectric grease between the connections in the bulkhead and the engine side and I am assuming the silicone sealant is that black sticky stuff?
As always, thank you for everything each of you contribute to this forum. I really could not have done this without your help...
Jeff B - truly a NEWBIE - knew absolutely nothing about cars at all - learning as I go. Thanks in advance for your help and patience.
MY PROJECT CAR
71 Malibu originally had 307 and sweep style dash but now it has a 383 and SS dash. Factory AC, HEI, TH350 updated wiring throughout
jbrockman is offline
post #2 of 3 (permalink) Old Feb 19th, 14, 11:43 PM
Steamy
Re: Newbie with 2 quick questions regarding AC wiring
One quick answer-
Don't use silicone on any wiring connector, the chemicals in it are corrosive and will cause problems. If you're looking for something to seal the bulkhead connector, use 3M strip caulk, available at paint & body shop supply stores.
I can't answer your 1st question, I don't know much about '71 wiring.
BillL
My Showroom
Ark68SS is offline
post #3 of 3 (permalink) Old Feb 22nd, 14, 3:11 PM Thread Starter
Can anyone help with my first question??
MY PROJECT CAR
This Thread is more than 2195 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
