69 Chevelle SS396 Ammeter - Chevelle Tech
post #1 of 3 (permalink) Old Feb 19th, 14, 5:12 PM Thread Starter
The ammeter in my dash cluster has stopped working correctly.The needle
started setting on full discharge, I checked battery and alternator and they came out ok, I even checked the voltage at the meter and the b and b/w wires have 12+ volts. Can I pull the meter out from the cluster? Or is a new tach cluster the best remedy. I've read all the info on the forum for the past week done all the tests listed for ammeter problems and have not been able to get the needle to move back to the center.
jimlball is offline
post #2 of 3 (permalink) Old Feb 22nd, 14, 1:43 PM Thread Starter
Re: 69 Chevelle SS396 Ammeter
I just rechecked and the alternator, on the blue wire it has 9.9v running 4.14 key off ,on the white 7.27 running 0 off, and 14.5 on the red running then 12.67 off. Ideas?
jimlball is offline
post #3 of 3 (permalink) Old Feb 28th, 14, 5:44 PM Thread Starter
Ok easy question then. Can the ammeter be replaced?
jimlball is offline
This Thread is more than 2154 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
