Dim Headlight - Chevelle Tech
post #1 of 9 (permalink) Old Feb 13th, 14, 4:23 PM Thread Starter
Dim Headlight
I have nice and bright lights on the right side of my '70 SS but the inner left side light is out completely and the outer is much dimmer then light on the right side. Any ideas where i should start? Also there is a white wire attached to what looks like a capacitor bolted to the on voltage regulator, that wire is hanging on by a thread on the clip side. What does it do and any ideas on how to get another one?
Thanks as always
1970 LS6 is offline
post #2 of 9 (permalink) Old Feb 13th, 14, 5:15 PM
Re: Dim Headlight
Sounds like a poor ground.
mwiggett is offline
post #3 of 9 (permalink) Old Feb 13th, 14, 6:07 PM
Levon
Re: Dim Headlight
And or a badly corroded high beam terminal. Check and clean all of the connections.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #4 of 9 (permalink) Old Feb 14th, 14, 10:08 AM Thread Starter
Re: Dim Headlight
Thanks, any idea on the Voltage Regulator?
1970 LS6 is offline
post #5 of 9 (permalink) Old Feb 14th, 14, 10:22 AM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
Re: Dim Headlight
Bad ground or a bad bulb or try swapping out the bulb and test it.
I started with Nothing and still have All of Nothing!
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
post #6 of 9 (permalink) Old Feb 14th, 14, 10:58 AM
Levon
Re: Dim Headlight
Noise supressor for the AM radio. Won't affect charging. They are ALMOST the same as the one in the distributor.
It's called a capacitor.
http://www.ss396.com/part/GRC-12834.html ouch .
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #7 of 9 (permalink) Old Feb 14th, 14, 5:48 PM Thread Starter
Re: Dim Headlight
Thanks Levon that is what I thought is was. I see one for sale in the NPD catalog.
1970 LS6 is offline
post #8 of 9 (permalink) Old Feb 14th, 14, 7:32 PM
Re: Dim Headlight
My left side lights were dim also. First I checked the voltage at the inside ( two post) headlight with a voltmeter, set the meter to DC volts and connecting one lead to the negative - post of the battery and the other to one side of the headlight (on head light itself, not plug). Meter read battery voltage, 12+ volts approx. Next I connected meter to the other terminal on the same lamp, meter read battery voltage. This told me headlight was good and getting voltage but was not being grounded. I found a broken ground wire which connected both lamps on that side to ground. Hope the helps. Ground was laid under one of the voltage regulator mounting screws. My not be correct but that was where it was landed on my 70.
25C 70 is offline
post #9 of 9 (permalink) Old Feb 14th, 14, 11:19 PM
Louis
Re: Dim Headlight
Do a continuity test with DVM, set it X1 ohm and check the black wire from each headlight socket to the ground lug. It should read zero ohm. If read "0", Then either have a poor ground or a loose connector.
Louis
Original owner
lg1969 is offline
This Thread is more than 2304 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
