Key Accessory circuit on '70 tilt - Chevelle Tech
post #1 of 4 (permalink) Old Feb 12th, 14, 7:13 PM Thread Starter
JPS
I have a 70 El Camino w/original wire harness in a sweep dash, feeding [exact year unknown] GM recycled tilt column. The install was down by a long gone mechanic years ago when I found the 're-built' tilt. Looks stock part for 70-72 GM [BPO?] and everything works [wheel is centered, horn signals, and Flasher work, except I never noticed the 'Accessory Power' not working, since I only recently installed a radio-cd.
I removed the AC vent cowl below the column which exposed the long wire plug mounted on the column and tested every terminal I could get my multimeter probe point into. As I recall, of the 8 or 10 probed, two were 'Hot'; maybe horn and buzzer or Flasher?
The remianing being turn signals and maybe be the Accessory power, but no dice with multimeter and key turned back into Accessory position.
I'll post a pic later on this long terminal or junction to see if anyone recognizes it.
Down the column and immediately adjoining is another terminal, but with maybe only 4 or 5 'ports' , but empty [no wiring].
Also, to further search for an 'Accessory Circuit', I found what I believe was my original radio power & ground feed; 3 wires: Black, Yellow & Grey. I'm guessing the Yellow & Brown were power for radio and radio lighting, with Black for ground. The ground works [tested to the cig lighter], but the others are dead.
At the moment, the only way to power up the radio, with the engine off, is to turn to the Start position. I converted to an HEI distributor and electric choke Edelbrock long ago, but it's probably not energy efficient to listen to the radio with the start circuit energized; probably not good for the coil either.
If the Accessory power was just never wired to the key switch in the tilt install or rebuild, any options to wire one in now?
Any comments or suggestions welcome- pictures will follow.
Thanks,
JPS is offline
post #2 of 4 (permalink) Old Feb 12th, 14, 7:38 PM
Re: Key Accessory circuit on '70 tilt
If the key will turn past "lock" to the acc position, and nothing works, I suspect the switch may need to be adjusted on the column. Might play with the adjustment a little and see if that helps. Might be a bad switch too, might try plugging in another if you have one and see if that will power up the accessories.
Good luck, Jim
72 Chevelle SS conv
72ragtop is offline
post #3 of 4 (permalink) Old Feb 13th, 14, 2:38 AM Thread Starter
JPS
OK. Didn't know it could be adjusted.
I'll search for a thread on it.
JPS is offline
post #4 of 4 (permalink) Old Feb 13th, 14, 5:39 AM
Levon
You just loosen the 2 little screws and move it up or down the column as needed. BTW tilt switches are different than std columns. They work opposite of each other so make sure you have a tilt switch.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
This Thread is more than 2173 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
