69 Turn signal/brake light issues - Chevelle Tech
post #1 of 10 (permalink) Old Jan 27th, 14, 5:16 PM Thread Starter
Thor
I know this is an old post, but can anyone give me a hand? Im trying to restore a 69 malibu, but cant figure the way to fix the signal lights. What lights are the ones that flash in the front when you signal? Same for the back. It seems im not getting power to the rear brake/signal lights. ANY help is appreciated.
cmbtmdcthor is offline
post #2 of 10 (permalink) Old Jan 27th, 14, 5:23 PM
Shane
Re: Front signal lights 68 vs 69
1. where is there a Chevelle in Iraq? it sure the hell wasn't there when I was.
2. do you need a set?
get a multimeter and make sure your getting voltage to the light sockets.
fuses.
fishhead is offline
post #3 of 10 (permalink) Old Jan 27th, 14, 6:30 PM
JWA
Re: 69 Turn signal/brake light issues
Pulled out of another thread not directly related to this posting. It is always better to start your own thread so your issue is directly addressed and not lost in the mix of an older thread.
Bump for visibility...
Gold Founding Member #158
The TC Search >>
TC photo >>
JWA is offline
post #4 of 10 (permalink) Old Jan 28th, 14, 5:45 PM Thread Starter
Thor
fuses.
1. I opened this account when I was stationed in Iraq , never even knew that was still in my header lol.
2. Thanks for the info, I'll check the voltage
post #5 of 10 (permalink) Old Jan 28th, 14, 8:00 PM
The bulbs in the front and rear light housings have two elements - one for the park or running lights (dim) and one for the turn signals (bright). I start with the hazard lights to see if the lights come on. They are on a separate flasher unit and work without the ignition on. I check the brake lights, check the parking lights. Take an inventory of what works and what doesn't. Sometimes process of elimination you can guess where the problem is. Otherwise, start on the end and work to the start of the circuit or vice versa. Power to turn signal switch, power out of turn signal switch, power in and out of the brake light switch, etc. Don't overlook the grounds either.
Alan F is offline
post #6 of 10 (permalink) Old Jan 29th, 14, 1:54 PM Thread Starter
Thor
Wow thanks for that invaluable information. I have been hard at work trying to make these lights work. My problem now is that they are flashing in the wrong place. For example, when I turn to signal to the right....the top right AND bottom left lights flash?! And that's just in the back of the car. I have no flashing lights in the front at all. I think it's because I'm not getting power to the brown wire according to the wiring diagram. The brown wire powers Both the rear lights and the front marker lights and signal lights if I'm not mistaken. I had paid a guy to fix it, and he actually made things worse for me.
post #7 of 10 (permalink) Old Jan 29th, 14, 2:46 PM
The brown wire is normally for the park/running lights. It sounds as if you have a grounding issue. If you don't have a test light you should buy one. It will eliminate the guesswork about the grounds. I've also seen the wrong bulbs as the culprit too. If you don't know they should be 1157's. There is a dk grn wire and yellow wire in the back is the ones that need power.
Alan F is offline
post #8 of 10 (permalink) Old Jan 29th, 14, 2:50 PM Thread Starter
Thor
So the brown wire will have power, correct? I will buy a test light today and try to see if I can find the short and or mixed wires. Will post update today
post #9 of 10 (permalink) Old Jan 29th, 14, 4:23 PM Thread Starter
Thor
Question... Where does the reverse light socket (light green wire) go in the housing!? Does it go in the bottom hole or the top one?
post #10 of 10 (permalink) Old Jan 29th, 14, 6:46 PM
The brown wire (rear) will have power only when the park/running lights are on.
There is a separate, single element bulb for the backup lights. You should be able to distinguish it based upon its position in the housing which is near the bottom.
The yellow wire in the rear is the brake and turn signal on the left, and the dark green wire is for the right.
Alan F is offline
This Thread is more than 2217 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
