Has Anyone Used One Of These As A Column-Mount Tach? - Chevelle Tech
post #1 of 11 (permalink) Old Jan 24th, 14, 1:43 PM Thread Starter
Doug Davis
This is just another one of my one-off ideas, but I think this would look cool mounted perfectly centered on top of the column. The shape should allow it to fit close to the dash without covering the speedo numbers. If I used one of these hood tachs, I would have to shorten the back of it as much as possible so it's not too long, also to give it a flat back to fit up against the speedo face as close as possible. Here are some pics just for ideas. Suggestions are highly appreciated!Attachment 141594Click image for larger version
ID:	141602Click image for larger version
66 Chevelle
350/400 Turbo
12 Bolt Eaton Posi w/3:73's
Team Chevelle Member # 3540
davis95 is offline
post #2 of 11 (permalink) Old Jan 24th, 14, 1:51 PM Thread Starter
Doug Davis
Re: Has Anyone Used One Of These As A Column-Mount Tach?
Here's a pic of the front.
66 Chevelle
350/400 Turbo
davis95 is offline
post #3 of 11 (permalink) Old Jan 24th, 14, 4:58 PM
Bruce
I don't think it would work because of that cylinder on the bottom for the tach "motor," plus (IMO) it would look less than intelligent (i.e. stupid).
Our You Tube Vids:
NickeyChevelle is offline
post #4 of 11 (permalink) Old Jan 24th, 14, 11:55 PM
What about when the column rotates?
post #5 of 11 (permalink) Old Jan 25th, 14, 1:06 AM
Rocky Hill
Well Dean see below
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
rocks66ss is offline
post #6 of 11 (permalink) Old Jan 25th, 14, 8:24 AM
Banned
Cory
I've thought about trying to mount something like that in the dash of a 66 in the switch strip above the speedo but that unit you have is probably too big.
dream66 is offline
post #7 of 11 (permalink) Old Jan 25th, 14, 1:38 PM Thread Starter
Doug Davis
I will shorten it as much as possible, with my limit dependant on where the internals are located.
It only rotates if I manually turn the collar. It is a very snug collar and won't move by itself.
I think the potential cool factor here is to have a tach mounted right in the center of the speedo (and still see the speedo) and be able to see both of them in the same view.
66 Chevelle
350/400 Turbo
davis95 is offline
post #8 of 11 (permalink) Old Jan 25th, 14, 6:56 PM
Why not just mount it in the hood where it belongs?
oldcutlass is offline
post #9 of 11 (permalink) Old Jan 25th, 14, 7:12 PM
Bryan
Yep----no point in 'overthinking'.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
post #10 of 11 (permalink) Old Jan 25th, 14, 9:04 PM Thread Starter
Doug Davis
A Chevelle hood isn't made for one of these tachs. This is just an idea...nothing set in stone. I was hoping to get a few ideas to add to my idea. I don't own the tach in my pics. It's just a pic I found to illustrate my idea. Maybe there is another odd-shaped tach out there that will better suit what I'm trying to do.
66 Chevelle
350/400 Turbo
davis95 is offline
post #11 of 11 (permalink) Old Jan 27th, 14, 10:12 PM
Darren
Put a big fat one on the floor with a shift light, trust me you'll see it when you hit 8k!
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
This Thread is more than 2217 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
