66 chevelle front marker lights. - Chevelle Tech
post #1 of 6 (permalink) Old Jan 15th, 14, 7:50 PM Thread Starter
Chuck
when I turn on the head lights my front marker light go out. Is this normal.? the blinkers work either way. Head lights on or off.
ezthere is offline
post #2 of 6 (permalink) Old Jan 18th, 14, 7:44 PM
Doug Davis
Re: 66 chevelle front marker lights.
This is how they came from the factory. Headlight switch pulled halfway out-running lights only, pull switch all the way out-headlights only.
66 Chevelle
350/400 Turbo
12 Bolt Eaton Posi w/3:73's
Team Chevelle Member # 3540
davis95 is offline
post #3 of 6 (permalink) Old Jan 24th, 14, 10:16 PM
Rocky Hill
Here is a way to make the lights stay on when you turn the light switch on if you choose.
Starting in 1968, when side-marker lights were introduced, the parking lights remained on when the headlights were switched on. Prior to that model year,the parking lights switched off when the headlights were switched on. I believe this pertains to all GM vehicles.
Disconnect the battery first. Then disconnect the light switch from the dash, and drop it down below the edge of the dash. Before you unplug the wiring harness from the switch, look at the position of the purple wire in the connector. It will be in a slot which is at the end of the switch, farthest from the dash.
Look for an open slot in the connector which is at the other end of the connector, towards the dash. Remove the connector from the light switch, and then release the terminal of the purple wire from the connector using a small screwdriver (you do this from the light switch side of the connector).
Insert the terminal of the purple wire into the open slot of the connector which you identified earlier (the one closer to the dash). Then just reconnect the wiring harness
to the light switch, and reinstall the light switch into the dash, and reconnect the battery. Now the
parking lights will function as before in the halfway position, but remain on when the headlights are switched on.
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
rocks66ss is offline
post #4 of 6 (permalink) Old Jan 24th, 14, 10:23 PM
Rocky
Question;
What happens then if you just want the parking lights and taillights only to be on? Does the first pull out notch on the headlight switch still work?
post #5 of 6 (permalink) Old Jan 24th, 14, 10:43 PM
Question;
Yes. That doesn't change if you rewire the switch. The only difference is the terminal that the purple wire gets moved to is live in both the 1st & 2nd click positions.
I'm almost certain that the 68 & later cars were all wired this way from the factory given the federal mandate for marker lights beginning with the 68 model year.
Pete 67 is online now
post #6 of 6 (permalink) Old Jan 24th, 14, 11:00 PM
Thanks, I no longer have a pre 68 but was just curious about possible feed back voltage.
This Thread is more than 2360 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
