Generator Light - Page 2 - Chevelle Tech
post #16 of 19 (permalink) Old Mar 27th, 00, 11:17 AM
WuYah2
Guest
Posts: n/a
Yep, I am getting fuel . I have no idea what is wrong.
post #17 of 19 (permalink) Old Mar 27th, 00, 4:51 PM
If your sure you've got fuel than make sure you have a good hot spark and that it is happening at the right time. If you take your car to a mechanic he is going to charge you for finding this out. Was the distibutor out and put in 180 deg. off? Plug wires crossed. Distributor loose did it turn? If your sure you've got a good spark than turn the distributor while your cranking over to see what happens? Is your distributor turning when you crank it? Pull the cap and bump the motor---Good luck and keep posting
toanderson is offline
post #18 of 19 (permalink) Old Mar 28th, 00, 8:30 AM
Armando
I'm with toanderson. Double check to see if your spark is going off at TDC in the compression stroke. Your distributor may be 180 degrees off.
Armando
So. Cal
66 Malibu,454,M22
64 El camino
57 Bel Air
95 Impala SS
Mondo454 is offline
post #19 of 19 (permalink) Old Mar 28th, 00, 2:27 PM
WuYah2
Guest
Posts: n/a
Unfortunetly after days of tinkering I needed the car back and I am not very knowledgable of car stuff so I took it to the mechanic and he said the distributor was out of line with the engine and that it could only be this way if I removed the distributor (I didn't) or the timing chain jumped, which I am assuming the latter happened. Anyway, I just wanted to thank you all for your help. It is really appreciated. Thanks again.
-Jon
This Thread is more than 7089 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
