Pertronix Ignitor II - Chevelle Tech
post #1 of 5 (permalink) Old Jul 23rd, 03, 2:24 PM Thread Starter
Post
I know this has been tossed around previously, but was wondering if their are any new experiences with this product. I was thinking of updating my points distributor with either a GM type HEI or the Ignitor II with a new Flame Thrower coil and 7mm stock look plug wires. I guess I'm looking to keep it more on the original look. Does the distributor have to be removed to install this product? Appreciate any info you may have to have to offer.
67 SS Cpe
yellvelle is offline
post #2 of 5 (permalink) Old Jul 23rd, 03, 6:52 PM
Post
You don't have to take the distributor out, but you might have a slight problem getting the new wire and molded plug(on the wire) to seal in the thru hole in the distributor housing.....
Neat way to go....looks stock.....a bit of advice.......when you go to start the car....turn the key to the run position and wait about 5 seconds before starting the car as the module takes that long to energize itself.......took a while to figure that out......crank-crank....
Seems that's the only downside to this system......now that I do that it starts immediately.......
Ken [img]graemlins/thumbsup.gif[/img]
https://www.chevelles.com/showroom/SS396Convert/
66 Chevelle SS LSA Powered
66 Impala Convert LS 2 Powered
Whizzer MotorBike
SS396 Convert is offline
post #3 of 5 (permalink) Old Jul 24th, 03, 1:12 AM
Phil
Post
I've used both the Ignitor system and the one that M&H Fabricators sell = I like the one from M&H better ,One wire and easy to setup. Check em out www.wiringharness.com
Philip Mullaly
Machines don't matter.... People matter
pmullaly is offline
post #4 of 5 (permalink) Old Jul 24th, 03, 5:38 AM
Keith
Post
Although the HEI may not look stock, it works well, even on an L78 motor. If it does break down, any automotive parts store will have what you need to get you back on the road. For that matter, I've never had problems with points. With the amount of mileage that we put on these old cars, you might have to change the points every 3-4 years. An all out race car might be another matter.
Keith Tedford is offline
post #5 of 5 (permalink) Old Jul 24th, 03, 11:14 PM Thread Starter
Post
Thanks for the replies and info. Still undecided
67 SS Cpe
This Thread is more than 5808 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
