High Beam Indicator - Chevelle Tech
post #1 of 7 (permalink) Old Nov 30th, 13, 6:43 PM Thread Starter
Ben
High Beam Indicator
Hey everyone, Im working on a 72 Malibu and need a little info on the dash wiring.
The headlights work when i turn them on, and the high beams work when i press the floor switch but the high beam indicator does not come on. There is no power at the bulb. I followed the light green wire from the indicator bulb but it goes to a connector on top of the steering column which i think is the backup lamp switch. Im having a hard time following the wires from there, any wiring diagrams out there so i can figure out how the indicator light circuit is set up?
Im find posts showing pictures of the switches but not a wiring schematic. Thanks for any help
72 Malibu
350 with flat tops
Comp Cam XE268
4 barrel holley street avenger
hooker comp headers
edlebrock rpm air gap
TH350 trans 2000 stall
10 bolt 3.55:1 gears
Spskunk is offline
post #2 of 7 (permalink) Old Nov 30th, 13, 7:03 PM
Re: High Beam Indicator
Hi Ben,
In a '72 Malibu sweep dash, the high beam indicator bulb socket has (2) wires, light green and black. Black gets spliced to the other grounds feeds inside the dash harness. The light green wire travels through the dash harness and down into the fuse block assembly directly. It is not connected into the fuse block, but into the back half of the bulkhead connector pins. The bulkhead is what links the interior wiring to the engine compartment wiring. The pin responsible for sending out 12 volts to the high beams has (2) wires crimped on to it--one light green from the floor dimmer switch, and the other light green headed up to the bulb in question. This is where the connection takes place.
In order to access this to get a visual, you'd have to disconnect the engine side bulkhead connectors, then remove the fuseblock from the firewall, then split the bulkhead connection assembly from the rear of the fuseblock. Quite a bit of work--are you absolutely sure you have no 12 volts on the light green wire feeding the "bright" socket? How are you taking your measurement, from chassis ground or from the ground connection in the socket?
Coppertop is offline
post #3 of 7 (permalink) Old Nov 30th, 13, 9:52 PM
Darren
And totally worth it! Joe is correct; it is some work if you have not done it before. If you have, itís a 30 minute procedure, far less without power brakes (because you can see). This is essentially the heart of your car. Tying everything to everything, if you have strange problems, this is a great starting point.
Gauges will read better, lights will be brighter.. damn near everything will work better if done correctly. The forward harness and the dash harness are all female/male spade connections. Over 40 years of hot/cold/moisture/spiders/vibration and God only knows what else... these connection tend to become less than desirable.
Separate, clean and lube with dielectric grease. Might be the best thing you can do for your car electrically.
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
post #4 of 7 (permalink) Old Nov 30th, 13, 10:55 PM Thread Starter
Ben
Wow thanks for the good responses guys! Yes I have the bulk head harness connectors disconnected and the dash pulled because I'm fixing my speedometer. First time pulling dash was a pain. Opened a whole new can of worms. Lots of dirty dusty stuff needing to be cleaned under there. Can't say I'm a fan of the old plastic parts, I broke the plastic mounting studs for the wiper switch. Not sure what to do about that.
I will clean and reapply dielectric grease to connectors. That's a good idea. And yes I'm sure there is no power to the bulb. Checked chassis ground and ground terminal in the socket and replaced all the bulbs in dash.
I'll look at it again and see what I find.
Do u know where I can get the pins for the bulkhead connectors?
72 Malibu
350 with flat tops
Comp Cam XE268
hooker comp headers
Spskunk is offline
post #5 of 7 (permalink) Old Dec 1st, 13, 11:12 AM
"Plastic Welder" Re: High Beam Indicator
Black Siamese syringe 2 part epoxy yellow has some body. Used to fix one of these plastic studs behind dash of 71 Malibu. (And various other broken plastic bits) First butt glue the broken stud on. Then a band or blob of the epoxy around the outside for reinforcement.
Packaging says Devcon. Syringe says ITW Performance Polymers part #47809/22045.
(I've used also on chevelle grill, Toyota corner light assembly broken plastic stud, etc.)
Suggest test first to see how it holds parts (has a little more body than amber epoxy resin), how quick it sets, etc. Like most all epoxies, cure time is very temperature sensitive.
(My blue hi-beam indicator lamp used to need a light finger tap on the dash to wake up.)
dogsridewith is offline
post #6 of 7 (permalink) Old Dec 4th, 13, 6:46 PM Thread Starter
Ben
Ok so I wiggled something and the light is working again lol. I'll clean and tighten everything up. Thanks for the help.
Anyone know where I can get the terminals for the wires in the harness bulkhead connector ? They are like a spade but have a locking tab. I might rewire engine harness instead if buying one .
72 Malibu
350 with flat tops
Comp Cam XE268
hooker comp headers
Spskunk is offline
post #7 of 7 (permalink) Old Dec 4th, 13, 7:57 PM
Any respectable auto parts store should have OR be able to order the Packard 56 series connectors.
Here's just an example:
http://www.napaonline.com/Catalog/Ca...145_0282442033
http://www.napaonline.com/Catalog/Ca...147_0282442030
This Thread is more than 2372 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
