Factory temp gauge and aftermarket at the same time. - Chevelle Tech
post #1 of 8 (permalink) Old Nov 26th, 13, 9:44 PM Thread Starter
Can I hook up the single wire that feeds my factory gauge signal and the aftermarket to the same sensor at the same time?
jketron is offline
post #2 of 8 (permalink) Old Nov 26th, 13, 11:57 PM
Re: Factory temp gauge and aftermarket at the same time.
Most likely not. They probably require different sending units. Leave the factory one in place and jump the aftermarket one in another location IE on the intake near the thermostat housing if there is a port there.
BlueSS454 is offline
post #3 of 8 (permalink) Old Nov 27th, 13, 11:20 AM Thread Starter
I've got afr heads and there isn't a port. The one I'm using is the one by the manifold.
jketron is offline
post #4 of 8 (permalink) Old Nov 27th, 13, 11:28 AM
Could you drill and tap the manifold at one of the rear water ports?
71 Chevelle
LM7 5.3l genIII 295hp / Th-350 / Quick Performance 9 inch housing, Ford 3.55:1 Traction - Lok, Moser Axles, Gm Disc / Drum brakes.
LS & 9 inch Swap complete!!!
255/45/17 front, 275/40/17 rear, SPC Springs, Stock front suspension geometry + Koni Ds and UMI rear arms. Planning SC&C Stage II+ front
Turbine is offline
post #5 of 8 (permalink) Old Nov 27th, 13, 12:16 PM
Buck
I have seen upper radiator hose mounts that have a thread that you could install a sensor in!
Cruzin4Fun
1972 Chevelle
Dakota Digital VHX Gauges
Chris Straub full roller setup.
Retro .510/.492 221/223..108 Sep
Scat Full Rotating assembly
Icon Forged Pistons
DONTWANT2 is offline
post #6 of 8 (permalink) Old Nov 27th, 13, 4:05 PM
I'm in the same boat- my temp sender is now in the manifold and I got a water neck with a boss that I put sender in for the electric fan control.
1970 Monte in the 11s
1968 Camaro in the 10s
Street Cars are More Fun!
jburns is offline
post #7 of 8 (permalink) Old Nov 27th, 13, 5:48 PM
Kevin
I tried to hook them up together and neither worked. The resistance is wrong or something. I tapped a hole in the intake right next to the water neck and everything works as it should.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #8 of 8 (permalink) Old Nov 27th, 13, 8:35 PM
No. The whole system is based on a voltage divider system. When you "add" to this simple circuit, now each gauge will be "reading" what they see--the sender with both gauges attached upsetting the original balance.
Coppertop is offline
This Thread is more than 2451 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
