Battery drain - Chevelle Tech
post #1 of 10 (permalink) Old Nov 24th, 13, 12:33 PM Thread Starter
Battery drain
Battery recently being drained. Some symptoms noticed are; dome light will not go out and key warning not working properly. thoughts? This is on a 69 Chevelle SS...
<img id="ums_img_tooltip" class="UMSRatingIcon"><img id="ums_img_tooltip" class="UMSRatingIcon">
Ed Hobbs is offline
post #2 of 10 (permalink) Old Nov 24th, 13, 1:13 PM
Re: Battery drain
Well, the dome light staying on would certainly be a cause for the battery drain.
What is the "key warning" doing?
By the way HTML codes are turned off.
post #3 of 10 (permalink) Old Nov 24th, 13, 1:16 PM Thread Starter
Re: Battery drain
the key warning was failing to turn off with door closed but now has become very intermittent and often inoperative. Could it be the horn relay?
Ed Hobbs is offline
post #4 of 10 (permalink) Old Nov 24th, 13, 1:20 PM
Re: Battery drain
Possibly, OR a bad door jam switch, OR an intermittent short to ground.
Does it shut off with the key removed?
post #5 of 10 (permalink) Old Nov 24th, 13, 1:23 PM Thread Starter
Re: Battery drain
the dome light stays on regardless if key is in ignition or not
Ed Hobbs is offline
post #6 of 10 (permalink) Old Nov 24th, 13, 1:26 PM
Mark
Re: Battery drain
Check your door switch and or circuit , also look at your light switch . Make sure the battery is good , have it load tested . For checking parasitic loads , remove the ground cable and reinstall it looking for a spark when reconnecting it , this indicates a draw on the battery . Disconnect components , like the starter and the altenator individually . With each component disconnected , reconnect the ground cable looking for a spark . If the spark disappears you have found your draw or parasitic load on the battery. This can also be done using a amp clamp on the positive and or the ground cable actually seeing how much amperage is being drawn with the load being applied . When the amperage load drops you usually find the component or circuit causing the parasitic load on the battery . Good luck
Boo.Man.1971 is offline
post #7 of 10 (permalink) Old Nov 24th, 13, 1:30 PM
Re: Battery drain
Sorry, I meant does the key minder act up with the key removed?
I would pull out the door jam switch and check it out since it would be the common thing for both problems.
Disconnect it's wires and tape them up for a temporary fix.
post #8 of 10 (permalink) Old Nov 24th, 13, 1:36 PM Thread Starter
Re: Battery drain
Thanks for the info. The Battery is brand new. The starter is brand new and the alternator is new. When connecting the battery leads there is no visual sign of a spark at all. I will keep looking at other things though. if you think of anything else i would appreciate the post. Thanks again.
Ed Hobbs is offline
post #9 of 10 (permalink) Old Nov 24th, 13, 1:43 PM
Mark
Re: Battery drain
Just a note on new parts , just because its a new component does not mean its good. It should be but sometimes this is not case .
post #10 of 10 (permalink) Old Nov 27th, 13, 10:41 PM
Cyrus
Re: Battery drain
X2 on Boo,Man.1971, Delco box made in Mainland China.
amx364 is offline
This Thread is more than 2381 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
