70 Elky 1 low beam is dim - Chevelle Tech
post #1 of 3 (permalink) Old Nov 23rd, 13, 12:58 PM Thread Starter
Frank
I searched the forum and checked my grounds, ran the meter to check and have what I believe is a new question. The power to the headlights routes down the drivers side and hits the driver side low beam first then routes over to the driver bright and then over to the passenger side, correct? If so, then why am I only seeing 6+ volts on the drivers low beam and the drivers high beam and both passenger lights are getting 12 volts? Still a ground issue??? By the way, all new headlights across the front of the Elky. Thanks.
Frank
Team Chevelle Member #2672 / 1972 Malibu - SS Clone
frankf72malibu is offline
post #2 of 3 (permalink) Old Nov 23rd, 13, 1:07 PM
Re: 70 Elky 1 low beam is dim
I believe you have a ground issue on the drivers side. I would check both sides to be sure. Using a jumper wire to a good chassis ground or direct to the battery will tell you a lot.
Toppless72 is offline
post #3 of 3 (permalink) Old Nov 23rd, 13, 1:25 PM Thread Starter
Frank
Yep, got to probing around with my meter leads and got the headlight to come on full bright just playing with the ground on the connector. And I could easily repeat every time. New connector for the drivers side low beam. Thanks!
This Thread is more than 2382 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
