64/65 amp meter shunt - Chevelle Tech
post #1 of 3 (permalink) Old Aug 9th, 00, 4:39 PM Thread Starter
The 64/65 gauge package,use and amp meter shut, thats located by the voltage regulator horn relay at the drivers side rad support.
1. Any idea where I can locate one ?
2. Could some one read the restance of the meter shunt so I can build my own.
thanks
Wayne KLine
ACES 1556
TCG 186
WayneK is offline
post #2 of 3 (permalink) Old Aug 10th, 00, 3:11 PM Thread Starter
ever one useing after market gauge packages ? Stumpead again.
Wayne Kline
with no Amp gauge in his Chevelle ARGHHHHHH
ACES 1556
TCG 186
WayneK is offline
post #3 of 3 (permalink) Old Aug 11th, 00, 10:44 AM
Hey Wayne...
This is something that comes up every once in a while. There are no readily available supplier's for this type of shunt. The after market AMP guages are different and have their own wiring for the purpose. An additonal point to keep in mind also, is that the maximum amperage that these & aftermarket AMP guages can handle is 60 amps. If you have a rebuilt alternator or a replacement one, it is most likely generating more than 60 amp's. Typically rebuilder's, redo them to 64 amps at minimum.
You are probably better off just leaving it dead and going out and getting a good volt guage.
Hope it helps.
Canadian ZZ4 Powered 64 Malibu SS!
Team Chevelle Gold Member #37
WebSite http://www.magma.ca/~ssoltesz/steves/1964.htm
Canuck64ss is offline
This Thread is more than 7239 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
