Good idea to wire fuel pump this way? - Page 2 - Chevelle Tech
post #16 of 17 (permalink) Old Aug 21st, 00, 10:33 AM
Bill,
No offense taken
Thank you for clearing up 69_Malibu's post. That's makes sense. Yes, I thought he meant the oil sender switch.
That is a good point. If you wanted this safety switch, I would connect the ground of the relay #85 to one side of the pressure sensor switch, the other side of the switch goes to a convenient ground. That way when the oil pressure drops, the relay loses it's ground, and turns off, and of course turns off the fuel pump.
Coppertop is offline
post #17 of 17 (permalink) Old Aug 22nd, 00, 1:54 PM
Jeff,
12 ga. should do. (10 ga. if your kinda of safety freak like yours truly, but you might have trouble finding 10 ga. in that length from an auto parts store.) So run 12 ga. to the #30 on the relay from the battery with a fuse on it, and 12 ga. from #87 on the relay all the way back to the fuel pump. Make sure that fuel pump has a GOOD sheetmetal ground. I wouldn't recommend the frame itself.
This Thread is more than 6874 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
