No Hi Beam on Passenger side - Chevelle Tech
post #1 of 5 (permalink) Old Oct 16th, 13, 8:11 PM Thread Starter
1966 chevelle, Replaced all four headlights 2 years ago, Never drove at night much, First dimmer switch didn't work, replaced it, (got a bad one) replaced it again, it worked, but later on I noticed my head lights on bright would blink on and off. Since then when I go to bright, driver side lights up both, passenger side none, switch bad to dim, both sides work on dim.
I cleaned the passenger side ground, bright bulb doesn't look blown.
I turned on lights, on bright and probed all the terminals with test light that didn't work, no voltage.
I suspect the dimmer switch, how do I test it?
Or is there another problem?
davehurst is offline
post #2 of 5 (permalink) Old Oct 16th, 13, 8:20 PM Thread Starter
Re: No Hi Beam on Passenger side
another bit of information, after reading here.
When I replaced all bulbs, I bought after market halogen
Could they be pulling to much power, Strange driver side works on bright
post #3 of 5 (permalink) Old Oct 16th, 13, 8:56 PM
If there is no power at the sockets terminals, there is your problem. No voltage, no lights. You need to figure out why no power is getting to the passenger side. Green wires get power on High beam, tan wires get power on Low beam. Tan and green never get power at the same time.
Coppertop is offline
post #4 of 5 (permalink) Old Oct 16th, 13, 10:21 PM
Ken
Try replacing your headlight switch. (not the dimmer switch) Had that happen to me one night...lights blinking. Changed switch and solved problem.
TODAY IS THE OLDEST YOU'VE EVER BEEN, YET THE YOUNGEST YOU'LL EVER BE, SO ENJOY THIS DAY WHILE IT LASTS.
Ken Hayes is offline
post #5 of 5 (permalink) Old Oct 17th, 13, 8:32 PM Thread Starter
And the winner is...Loose connection on the passenger side, cleaned tighten and fixed.
Thanks guys
This Thread is more than 2416 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
