Tach lead thru the firewall question - Chevelle Tech
post #1 of 5 (permalink) Old Oct 16th, 13, 6:45 PM Thread Starter
70 Chevelle SS manual with factory tach
Where does the brown wire come thru the firewall normally?
The prior owner had it running to a 6AL under the dash and I'm returning this back to the way it was from the factory... at least this part
jketron is offline
post #2 of 5 (permalink) Old Oct 16th, 13, 7:15 PM
Chevelle Doctor
Re: Tach lead thru the firewall question
There should be a hole above the gas pedal, on the flat area below the wiper motor. Ill post a pic when I get home tonite. Hole is 3/4".
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #3 of 5 (permalink) Old Oct 16th, 13, 8:14 PM Thread Starter
I see the hole you may talking about and mine has the cowl harness running through it.
jketron is offline
post #4 of 5 (permalink) Old Oct 16th, 13, 10:40 PM
Chevelle Doctor
Cowl induction should be in a hole at about 45 degrees northeast of the dash mat retainer hole.. if you have an automatic trans, there's two holes by that area...
70 Chevelle L78/M21
06 Equinox
post #5 of 5 (permalink) Old Oct 16th, 13, 10:52 PM
Chevelle Doctor
THis is an early KC L78 car with 4 speed, tach, and cowl Induction. THe hole about an inch and a half above, and just to the left of the accelerator cable hole, is the tach lead hole. The hole straight to the right of the accel. cable hole, is the Cowl Hood wire hole. Early cars had them up here at some plants, later they moved straight down about 2-3 inches to the vertical flat surface.(and just to the right of the dash mat retainer hole.)
70 Chevelle L78/M21
06 Equinox
This Thread is more than 2461 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
