red n white wires - Chevelle Tech
post #1 of 13 (permalink) Old Oct 15th, 13, 8:37 PM Thread Starter
Hector T
red n white wires
Hello guys....I am having problems keeping my alternator charge?...In restoring my !970 Chevelle...where are the red and white wires suppose to properly connect? Please help
Hector T is offline
post #2 of 13 (permalink) Old Oct 16th, 13, 3:51 PM
Re: red n white wires
i am looking at a stock 1970 wiring diagram, the red wires goes from Alt. to a Junction where it meets with the orange (#3 slot) wire from the voltage regulator and from there to the ignition switch. The red wire is the power wire, i usually run that directly to the J block next to battery -with a fusible link.
The white wire goes from Alt. to the #2 slot on the voltage regulator. This is for a stock set up.
voltage regulator slots
#4 #3 #2 "F"
brown orange white blue
68Cpe307 is offline
post #3 of 13 (permalink) Old Oct 16th, 13, 8:45 PM
Are you talking about a red and a white wire or a red with white stripe wire? Are they part of the charging system? Are you using the stock external regulator?
Becker is offline
post #4 of 13 (permalink) Old Oct 16th, 13, 9:01 PM
Hey Hector T
Chill out with the multiple posts man
We need more info.
Take a look at the back side of your alternator. Look at the small plug socket.
If the terminals look like this: l l
It's a factory style alternator that requires and external voltage regulator (external voltage regulators were mounted by the driver's side headlight buckets).
If the terminals look like this: __ __
It's an internally regulated alternator that someone has installed. These DO NOT use the factory voltage regulator at all.
Please let us know what you have for starters...
Coppertop is offline
post #5 of 13 (permalink) Old Oct 16th, 13, 10:26 PM Thread Starter
Hector T
Re: Hey Hector T
I have a -- side by side internal regulator style alternator...just don't know where white or red wires go
Hector T is offline
post #6 of 13 (permalink) Old Oct 16th, 13, 10:27 PM Thread Starter
Hector T
Re: Hey Hector T
sorry didn't know I was double posting
Hector T is offline
post #7 of 13 (permalink) Old Oct 16th, 13, 10:32 PM Thread Starter
Hector T
I am talking about the red and yes the white wires from my plug. It is an internal regulator style alternator
Hector T is offline
post #8 of 13 (permalink) Old Oct 16th, 13, 11:27 PM
Re: Hey Hector T
Hector,
Your aftermarket plug-in connector typically has the red on the right side and white on the left side (this is as you are looking at the rear of the alternator).
Although just connecting the red to the battery lug on the rear of the alternator isn't the ideal spot, it will get you going for now. The white wire needs to ultimately connect to the brown wire at the old voltage regulator plug.
Wes show's a blue wire being used, but as long as you get the correct terminal plug wired to the correct points, it should work (unless there are other issues like a faulty alternator)...
https://www.chevelles.com/techref/ftecref14.html
post #9 of 13 (permalink) Old Oct 16th, 13, 11:38 PM
Wink Re: red n white wires
Is this the plug you're talking about?
Becker is offline
post #10 of 13 (permalink) Old Oct 17th, 13, 6:46 PM Thread Starter
Hector T
Re: Hey Hector T
Thanks...I do have that same plug...my red wire is going to the battery terminal On rear of alternator...then another red one (we added it) straight to battery positive side...my white wire is still dangling...unconnected. Yes my car fires up and I can drive it...but once on road...it shuts off...and then won't start as my battery is drained (new battery by the way)
Hector T is offline
post #11 of 13 (permalink) Old Oct 17th, 13, 6:48 PM Thread Starter
Hector T
yes..very similar but red and white instead if yellow...
Hector T is offline
post #12 of 13 (permalink) Old Oct 17th, 13, 6:55 PM
White wire needs to go to one side of the "ALT"/"GEN" light with the opposite side connection at the light going to switched 12v power.
Becker is offline
post #13 of 13 (permalink) Old Oct 17th, 13, 7:53 PM Thread Starter
Hector T
thank you...will try...Trully appreciative
Hector T is offline
This Thread is more than 2453 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
