xeon headlights - Chevelle Tech
post #1 of 2 (permalink) Old Oct 15th, 13, 6:32 AM Thread Starter
scott
xeon headlights
Has anyone used these. Are they a improvement over halogen? Less draw on system?
http://www.ebay.com/itm/190928091730...84.m1423.l2661
Thanks scott
ecoman35 is offline
post #2 of 2 (permalink) Old Oct 15th, 13, 7:39 PM
Re: xeon headlights
Scott,
If they are truly direct replacements for the '6014's and the '6024's, the current shouldn't be an issue. I serious doubt they draw less. I couldn't find any specs on them. On my H5006 and H5001's I did my own regulated voltage tests. The drop in replacement Wagner Halogens drew approx. 1.5 amps more. Nothing to upset the apple cart unless your wiring and headlight switch questionable.
FYI, Rock Auto also sells these. You might even be able to get them locally. If you try them, post your results, I'm curious as I have always liked Wagner products.
Coppertop is offline
This Thread is more than 2427 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
