coil to ground voltage - Chevelle Tech
post #1 of 8 (permalink) Old Oct 14th, 13, 6:08 PM Thread Starter
Ron
On my 66 ss with stock ignition system, what should the voltage be when measuring from the positive terminal of the coil to ground, with all wiring connected and ignition switch on? I am getting about 6 volts. I am getting full battery voltage when the wires are disconnected from the coil, which is 12.5 volts.
Any help will be greatly appreciated.
Ron Bidwell
rbidwell is offline
post #2 of 8 (permalink) Old Oct 14th, 13, 6:11 PM
Re: coil to ground voltage
That sounds normal.
If the points in the distributor are closed, you cause a voltage drop (because remember there is a resistance wire feeding the coil's (+) that limits current. Therefore you will read less than battery voltage. If the points are open in the distributor, the circuit is open, thus no current and no voltage drop and you'll read battery voltage on the coil's (+).
Coppertop is offline
post #3 of 8 (permalink) Old Oct 14th, 13, 6:14 PM
Depends if the points are closed or not. I can't remember ever checking it myself but I've always heard around 9 volts (under load)
Checking with wires not connected or with points open doesn't really mean a lot.
{EDIT} oops, didn't see Joe's post.
post #4 of 8 (permalink) Old Oct 14th, 13, 7:54 PM Thread Starter
Ron
Thanks guys.
rbidwell is offline
post #5 of 8 (permalink) Old Oct 14th, 13, 8:16 PM
What are both the coil + to engine ground voltage at IDLE and 2,000 RPM's, and + post to - post BATTERY readings, at both those RPM levels?
Engine running load will tell the real tale. Static readings, no real info.
Dave Ray is offline
post #6 of 8 (permalink) Old Oct 14th, 13, 8:21 PM Thread Starter
Ron
Good point. If I ever get this thing to run I will check those readings.
rbidwell is offline
post #7 of 8 (permalink) Old Oct 15th, 13, 3:30 PM Thread Starter
Ron
At 2000 rpm I am getting a little over 14 volts when hooked to the positive terminal of the coil and to the ground. When hooked up to the negative side I am getting about 6.5 volts.
rbidwell is offline
post #8 of 8 (permalink) Old Oct 15th, 13, 11:44 PM
Don't really care about negative term on the coil to ground, doesn't make any diff. Positive on coil to ground, that is important, along with across battery at same rpm's. You outlined findings in the other topic. Please post there what alternator/regulator combo.
Dave Ray is offline
This Thread is more than 2418 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
