Disconnect fuse block/front harness - 72? - Chevelle Tech
post #1 of 8 (permalink) Old Oct 12th, 13, 12:31 PM Thread Starter
I'm having trouble figuring/seeing how to disconnect the fuse block from the front engine harness connectors. How are the two wire connectors attached? It's a Malibu/sweep dash if it makes a difference.
And can this be done from inside the car after removing the fuse block from the firewall or do I need to do it from the engine compartment?
1972 Chevelle - 350 - TH350
Va72Chevelle is offline
post #2 of 8 (permalink) Old Oct 12th, 13, 12:53 PM
Re: Disconnect fuse block/front harness - 72?
Remove the two harnesses from the engine compartment first by removing the hex screw. (as I recall it's 3/8")
post #3 of 8 (permalink) Old Oct 12th, 13, 10:36 PM
Darren
I think Dean is correct…. Although the “pin out” changed significantly in 72….. 70-72 all attached the same as far as the inner and outer harnesses go. (To the fuse block)
Matter of fact the 72 (dash) harness will mate with the 70 (engine) harness, but unless you change the entire pin out and then some…It will basically blow up
Ask me how I know This is my supposed “can’t be done” 72 Monte Carlo dash (note the fasten seat belts light by the lighter, that now reads “LINE LOCK” when it’s engaged) in my 70 Chevelle Malibu.
ALSO -
Only going on a tangent because I’ve done a few….
If you don’t push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system – Boss 338 18’s - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I can’t remember
70 nialator is offline
post #4 of 8 (permalink) Old Oct 14th, 13, 1:47 PM
There are two bolts/ screws holding the fuse block to the firewall. There is also a bolt on the engine side of the firewall that goes into the fuse block from the backside. This bolt should be removed first so that when you remove the two screws on the inside holding the fuse block in place the forward engine compartment harnesses and the dash harness will separate. The bolt is between the forward lamp harness and the engine harness. Dean is correct, it is a 3/8.
RealRed70 is offline
post #5 of 8 (permalink) Old Oct 14th, 13, 2:12 PM
Darren
On the inside or the car, about 2 and 7 o'clock (or top right and bottom left) 7/16 head and about 3 inch long.
USMC- Retired
post #6 of 8 (permalink) Old Oct 14th, 13, 3:16 PM Thread Starter
Thanks, got it.
post #7 of 8 (permalink) Old Oct 14th, 13, 10:04 PM
Darren
So…. I have to ask Steve….. What are you do'n? The average Joe does not take this apart…..
USMC- Retired
post #8 of 8 (permalink) Old Oct 14th, 13, 10:13 PM Thread Starter
Darren: I'm replacing the dash harness as part of a dash swap.
This Thread is more than 2230 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
