65 amp gauge /alternator charging - Chevelle Tech
post #1 of 5 (permalink) Old Oct 10th, 13, 9:00 PM Thread Starter
jim
hello , i put a 65 chevelle ss gauge package in my 64 elcamino ,and only thing i had to change was idiot light for temp end , and add wires for the amp gauge , i read on here one wire goes to battery and other goes to horn relay , i did that and it seamed to work fine then after sitting for a week i started car and it was not working it would go to almost dead ,idle and then all the way to charge when i reved it and i noticed when i disconnect the wire to the gauge the alternator does not charge to the battery volt meter sits at 11.98 ,, new alternator it used to pump out 13, 14 volts , before , ? did i short something ... i hooked one wire on horn relay the screw and that was 14 wire and used a 12 gauge on the battery side
64elko is offline
post #2 of 5 (permalink) Old Oct 11th, 13, 12:54 AM Thread Starter
jim
Re: 65 amp gauge /alternator charging
checked again and tinkered ,and its weird when i hook up the amp gauge the alt works ,and when i disconnected it dont charge ,,, strange because the amp gauge has nothing to do with alternator , anyone ever have this problem ? ,, plus headlights dont work now and all plugs fuses are hot and wires ,, i tell ya these old cars ,, are getting to me ,, any advice or thougts ,
64elko is offline
post #3 of 5 (permalink) Old Oct 11th, 13, 3:06 PM Thread Starter
jim
wow no thoughts ,, well i figured out headlights the ground wire coming from headlight next to battery broke , so i fixed it lights work , but alt still no go so i disconnected voltage regulator ,and it made no difference so i assume it must went out same time or right after i hooked up the amp gauge ,a coincidence.. ,, but thanks for the help , hahahaa ,,
64elko is offline
post #4 of 5 (permalink) Old Oct 11th, 13, 7:05 PM
Hank
Wouldn't expect alt to work with vr disconnected. Hook up amp gauge, check voltage at the 4 wires going to voltage regulator and 2 wires going to alt, not the main output wire. Do the same with amp gauge disconnected. I don't understand it, you're right the amp should have no impact on the alt charging but since it does figure what changes.
Hank
Finally is offline
post #5 of 5 (permalink) Old Oct 11th, 13, 11:09 PM Thread Starter
jim
i put a voltage regulator i had laying around , and it works fine now , ,, i will run it for a few days and let it sit and see it if burns out , with battery hooked up , ,, shows 15.98 and drops to 14.43 , 35 amp
64elko is offline
This Thread is more than 2419 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
