alternator not supplying power to car, battery is. - Chevelle Tech
post #1 of 14 (permalink) Old Oct 8th, 13, 1:02 PM Thread Starter
Gossamer (Mike)
Alternator checks out fine. Voltage regulator Fine.
Battery is supplying power instead of alternator.
Any steps on tracking This down?
Car dies when headlights are turned on.
My version of the never made '72 SS454 Chevelle Wagon.
454 ATK Engine/550 HP/575 TQ/4.10
gear/T-350 trans./3400 ATI conv/B&M Comp. Shifter/ 1/4 ET-12.39 @108mph - 1.69 60ft.
"Bet I can get to the Grocery Store and back Home first!"
Gossamer454 is offline
post #2 of 14 (permalink) Old Oct 8th, 13, 3:58 PM
Ken
Re: alternator not supplying power to car, battery is.
The battery supplies the power and the alternator is designed to maintain the charge in the battery. If you have an alternator on your car, you do not have a voltage regulator. Voltage regulators are used with generators.
If it was me, I'd replace the battery and alternator.
TODAY IS THE OLDEST YOU'VE EVER BEEN, YET THE YOUNGEST YOU'LL EVER BE, SO ENJOY THIS DAY WHILE IT LASTS.
Ken Hayes is offline
post #3 of 14 (permalink) Old Oct 8th, 13, 4:04 PM
What makes you think that it is running off of the battery Mike?
Did you check the alternator voltage output or how do you know the alternator is OK?
Headlights should run off of the battery also unless it is very low.
post #4 of 14 (permalink) Old Oct 8th, 13, 4:08 PM
Alternators have voltage regulators, some external, some internal but our old Chevelles originally had the external type.
Actually, alternators are generators.
post #5 of 14 (permalink) Old Oct 8th, 13, 5:52 PM
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
Strange 12bolt w/4.10
1971ss454Elco is offline
post #6 of 14 (permalink) Old Oct 8th, 13, 6:32 PM
Ken,
The alternator is designed to provide all of the power for the vehicle, in addition to providing charge current to the battery. The battery is used for starting, filtering the output of the alternator and provides limited reserve for accessories when the engine is not running.
All charging systems use a voltage regulator. Doesn't matter if it is generator from 1928 or a 2003 alternator (a.c. generator).
Marc, You have a voltmeter right??
What is the voltage at the battery with the engine idling between 1500 to 2000 rpm's ?
Coppertop is offline
post #7 of 14 (permalink) Old Oct 8th, 13, 6:40 PM Thread Starter
Gossamer (Mike)
The alternator has neen checked. Its putting out fine.
When i unhook battery car dies. When it sits for awhile i can restart it until battery is drained and it dies.
Voltage regulator is new.
post #8 of 14 (permalink) Old Oct 8th, 13, 6:45 PM Thread Starter
Gossamer (Mike)
Yes i have a voltmeter.
And yes, i have a wife that has a ton of chores for me currently.
If i go out there near car right now its like she has some internal alarm that knows.
Ill get to it as soon as possible and post my findings. Thanks
post #9 of 14 (permalink) Old Oct 8th, 13, 7:27 PM
Mark
Check voltage at battery before starting and check again with engine running . A good example would be 12.5 volts before start up and a reading of 13.
to 14.5 with engine running . Place load on the alternator with lights on and turn A/C on if you have it , the voltage should stay the same or drop slightly , say half a volt. If it drops below the 12.5 volts read before the engine was started . The alternator or charge circuit is not working with the load applied . You said the alternator was checked and it was ok , but did the alternator get tested with a load?
Boo.Man.1971 is offline
post #10 of 14 (permalink) Old Oct 8th, 13, 8:03 PM
Okay, Get the Honey-Do list done first to avoid injury
Other thoughts to bear in mind...
You should see at least 13.8 volts at the battery terminals with the 1500-2000 rpm idle (with no major loads turned on). 14.2 is the ideal charging voltage.
NEVER disconnect the battery when the engine is running. This is referred to as open load on the alternator. One of the first things GM and Delco-Remy warn you not to do in any service manual. That is not a valid test and you can damage equipment that way.
A fully charged battery with no parasitic loads on it will read approx. 12.65 volts at rest.
"It tested good". If I had a dime for every time I heard that I would have a lot of dimes. It's just like "but it's a new replacement". It means nothing until troubleshooting rules it out.
post #11 of 14 (permalink) Old Oct 8th, 13, 8:13 PM Thread Starter
Gossamer (Mike)
Ok im going to check what you guys recommended as soon as i can. Thanks, guys.
post #12 of 14 (permalink) Old Oct 9th, 13, 8:40 AM
Hank
Is the GEN light on with engine running? Should be if the bulb is good and the wiring is good. Voltage from ignition switch goes through the bulb and to the VR.
Look through the following post, there is a writeup by Peter F that will help diagnose the problem.
https://www.chevelles.com/forums/show...596&highlight=
Hank
Finally is offline
post #13 of 14 (permalink) Old Oct 11th, 13, 9:36 AM Thread Starter
Gossamer (Mike)
The only thing I haven't changed is the ignition switch. I'm going to change that out. This may be explaining the starting problem as well.
I'll post my findings.
post #14 of 14 (permalink) Old Oct 14th, 13, 7:13 PM Thread Starter
Gossamer (Mike)
Ok, got it fixed.
It was the ignition switch. All is good once again with the Wagon. Now to make a run to the grocery store.
This Thread is more than 2416 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
