remote starter solenoid just clicking....not starting - Page 2 - Chevelle Tech
post #16 of 28 (permalink) Old Oct 7th, 13, 8:37 PM Thread Starter
Gossamer (Mike)
Re: remote starter solenoid just clicking....not starting
Ugh! Now when it doee start engine is running off the battery!
I cant figure this out.
My version of the never made '72 SS454 Chevelle Wagon.
454 ATK Engine/550 HP/575 TQ/4.10
gear/T-350 trans./3400 ATI conv/B&M Comp. Shifter/ 1/4 ET-12.39 @108mph - 1.69 60ft.
"Bet I can get to the Grocery Store and back Home first!"
Gossamer454 is offline
post #17 of 28 (permalink) Old Oct 7th, 13, 8:40 PM
What do you mean the engine is running off of the battery? No alternator output? No turn-off with ignition switch?
Coppertop is offline
post #18 of 28 (permalink) Old Oct 7th, 13, 8:48 PM
Originally Posted by Coppertop View Post
That description of troubleshooting makes no sense.
Sorry I meant to say it was the solenoid in the starter.
Is your starter wired like this?
oldcutlass is offline
post #19 of 28 (permalink) Old Oct 7th, 13, 8:50 PM Thread Starter
Gossamer (Mike)
Engine not running off alternator. And headlights, etc etíopes workin.
post #20 of 28 (permalink) Old Oct 7th, 13, 8:55 PM Thread Starter
Gossamer (Mike)
Ok, no charge coming from alternator. Battery drained down.
post #21 of 28 (permalink) Old Oct 7th, 13, 8:58 PM Thread Starter
Gossamer (Mike)
I did have it hooked that way, but i hooked it up the way Dean said to. It started right up but now i have no charge from my alternator
post #22 of 28 (permalink) Old Oct 7th, 13, 8:59 PM
Okay then...
You have two issues to resolve.
What kind of alternator? 1-wire, internally regulated, original externally regulated?
Is your wiring fairly stock, or mainly modified?
post #23 of 28 (permalink) Old Oct 7th, 13, 9:03 PM Thread Starter
Gossamer (Mike)
Externally regulated
post #24 of 28 (permalink) Old Oct 7th, 13, 9:04 PM Thread Starter
Gossamer (Mike)
Stock wiring
post #25 of 28 (permalink) Old Oct 7th, 13, 9:05 PM Thread Starter
Gossamer (Mike)
Only thing i havent changed is the ignition switch.
post #26 of 28 (permalink) Old Oct 7th, 13, 9:10 PM
Start by charging (assuming its not too far gone) the battery. You will need it for the alternator/voltage regulator checks.
Do you have a spare battery (or one you can rob from a daily driver?)
post #27 of 28 (permalink) Old Oct 7th, 13, 9:23 PM
Originally Posted by oldcutlass View Post
The next time it acts up have someone turn the key and whack the starter with a hammer. If it starts it's the starter solenoid.
I've always found if tapping the starter makes it start working, it's because the brushes are worn down short and the jar causes them to re-make contact with the armature.
post #28 of 28 (permalink) Old Oct 8th, 13, 12:57 PM Thread Starter
Gossamer (Mike)
Dean your suggestion of relocating the wire worked. Turning over quickly, but now alternator is not powering car. Battery is powering everything. New topic.
This Thread is more than 2422 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
