Dual relays for halogen lights kits - Chevelle Tech
post #1 of 14 (permalink) Old Aug 1st, 13, 2:00 PM Thread Starter
Send a message via AIM to psi3000
Check this out:
http://www.ebay.com/itm/CERAMIC-H4-H...c662d5&vxp=mtr
for $47 shipped. I think its a deal, correct me if Im wrong. I was pricing up all the plugs and this just seemed to make more sense.
psi3000 is offline
post #2 of 14 (permalink) Old Aug 1st, 13, 2:22 PM
Re: Dual relays for halogen lights kits
Interesting.... subscribed to see what kind of responses this generates!
70 Chevelle
496 cu. in. "cruiser"
Assembled & Tuned by Mo's Speed Shop Dallas, GA
fleming23 is offline
post #3 of 14 (permalink) Old Aug 1st, 13, 3:00 PM Thread Starter
I was thinking about doing some research and holding off, but now I think Im just going to buy one.
psi3000 is offline
post #4 of 14 (permalink) Old Aug 2nd, 13, 9:53 AM Thread Starter
Let you know what I think when I get it.
psi3000 is offline
post #5 of 14 (permalink) Old Aug 2nd, 13, 10:36 AM
Darren
I know it says 100 Watt halogen max but I wonder if those are 30 amp relays…. Typically that clear stuff is kind of garbage. Easy to replace in any case
If you don’t push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system – Boss 338 18’s - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I can’t remember
70 nialator is offline
post #6 of 14 (permalink) Old Aug 2nd, 13, 1:59 PM
I'll type something up on this later. I give 'em credit, but see a lot of issues.
Coppertop is offline
post #7 of 14 (permalink) Old Aug 2nd, 13, 7:56 PM
Okay,
It's up to you, maybe you'll have good luck, but here's things I spotted and I don't like about this set-up.
-Zoom in close to the components and the sticky label on the tubing. This appears to be 100% Chinese made.
-Relays--as Darren stated, the clear ones are meant to "look cool", but are usually cheap garbage regardless of what rating they state on them (if they even do state factual ratings).
-Fuse holder is the cheapo plastic retainer style. No rubberized/sealed water/dirt/corrosion resistance at all
-Split ring connectors. Not a good idea. When you go to tighten the connection screw/bolt, whatever, they tend to bend and slip out of place.
-I don't like fuses or fuse links in headlight circuits. "One and you're done". They blow from overload or heat from corrosion build-up and you're driving down the road in complete blackness. I use breakers just like the factory. At least you'll get "flashing" to guide yourself to the side of the road during intert overload.
-It claims "ceramic sockets". Take a close look. The center *may* be ceramic, or a cheapo thermoplastic knock-off. The blue housings around the supposed ceramic are nothing more than light weight plastic.
-The instructions show fusible links. The kit has a fuse. Huh?
-The plug that plugs into the existing factory socket is a nice selling point, but it introduces another point of failure as there is nothing that locks the two plugs together and I'm sure someone will plug one into their most dirty, corroded, nasty headlamp plug and call it good rather than making a good splice.
-The price says it all.
-Does this look familiar? http://www.ebay.com/itm/H4-9003-Harn...-/180768073611
post #8 of 14 (permalink) Old Aug 2nd, 13, 10:39 PM
Smile Re: Dual relays for halogen lights kits
I think this guy's stuff is good:
http://www.madelectrical.com/catalog/rly-1.shtml
About the same price as the ebay junk for 2 kits.
David
http://www.cardomain.com/ride/307290...rolet-chevelle
davewho1 is offline
post #9 of 14 (permalink) Old Aug 6th, 13, 1:43 PM Thread Starter
I got it yesterday. Copper you are right the headlight connectors are ceramic but the outside is the cheep plastic. And I don't see this blade connector on my 70. Am I missing something? Maybe I have to look more.
I also saw the cheep see-through relays and thought the same thing. However I have lots of Boush relays from the junk yard that should work.
However, if this works and the plastic on the connectors hold up it will do exactly as I wanted. I should have brighter lights with little install time. Instead of having to build the harness myself. I will eventually go the BMW HID route , but for now this should suffice .
psi3000 is offline
post #10 of 14 (permalink) Old Aug 28th, 13, 5:49 PM
Pete
Any update on how the install went and if there was a marked improvement?
I ran across this as well. Basically an identical item , but using better parts? and made in USA? Not sure if its worth more then double the price.
http://67-72chevytrucks.com/vboard/s...d.php?t=512511
Here are the ebay links
So $110 vs $47 ???
http://www.ebay.com/itm/CERAMIC-H4-H...2e52f4&vxp=mtr
or
http://www.ebay.com/itm/161091602580...84.m1423.l2649
__________________________________________
1970-1 Chevelle (307ci w/PG) Now LS 6.0 w/4l60E
Progress Pics.
http://photobucket.com/BigOiBoyChevelle
LS Swap
https://www.chevelles.com/forums/141-...lq4-build.html
BigOiBoy is online now
post #11 of 14 (permalink) Old Aug 28th, 13, 7:39 PM
Pete,
It really looks to be about the same exact set-up to me. Might be a few better quality parts, but the same issues I outlined above still are issues.
Another thing to be careful of, "Made in the USA" can be interpreted many ways. I have a feeling this product should say "Assembled in the USA with foreign components".
post #12 of 14 (permalink) Old Aug 28th, 13, 9:04 PM
Darren
Unless you are using some aftermarket, upgraded bulb… even running 0 AWG directly from the battery is not going to make much difference. Wire is inexpensive and wiring a relay is easy. I will agree that the 45+ year old sockets leave a little to be desired, that's why I didn’t use them at all….
You can make one of these harnesses for much less and it will be way better, with a little research and reading you can doing just about anything to these cars.
This brings me to my rant and I should start a new thread for this…. I heard on some car TV show the other day, the owner of the shop said “internet mechanic” and BASHED us all. What an A$$!! Read, learn and do it yourself. That’s what these old cars are for
USMC- Retired
post #13 of 14 (permalink) Old Jan 20th, 14, 9:17 PM
Levon
I put halogen sealed beams in mine. No extra draw and lots of light. Fit the buckets just like any other sealed beam.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is online now
post #14 of 14 (permalink) Old Jan 20th, 14, 9:26 PM
Darren
See above.. Phantom works is the show I was referring to… as much as I LOVE car shows during the winter.. I refuse to watch that one just because the owner is a DOUCHE!
Sorry, off subject.. I'll let it go.
Back on subject… I did this https://www.chevelles.com/forums/showthread.php?t=400257
Several pics and VID on my car here.. for 50.00 bucks. Lots of chopping and work but TOTALLY worth it IMHO.
USMC- Retired
This Thread is more than 1975 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
