Upgrade horn relay and wiring? High amp alternator - Chevelle Tech
post #1 of 8 (permalink) Old Jun 10th, 13, 11:52 AM Thread Starter
Curley8788
I have a 160 amp alternator. Internally regulated. I have a HUGE voltage drop between the alternator and the battery. I need to upgrade my wiring to and from the horn relay. I planned on adding a couple more 10 gauge wires or so. What is the easiest way to do this? I read somewhere i can replace the horn relay with a junction block of some sort? What should i be looking for and does anyone have a wiring diagram for the new block?
1968 Chevelle
376Shovel is offline
post #2 of 8 (permalink) Old Jun 10th, 13, 12:37 PM
Re: Upgrade horn relay and wiring? High amp alternator
I ran a #8 wire direct from alternator to battery; left all other wiring intact. Works fine.
'66 SS396 502-502; '71 SS454 Convertible
RCBach is offline
post #3 of 8 (permalink) Old Jun 10th, 13, 12:43 PM
Jason
http://madelectrical.com/catalog/cn-1.shtml
Here is what your looking for. Be sure to look at the Electrical Tech section on their site as well.
_________________________
'70 Chevelle
Current build:
Blownchevelle68 is offline
post #4 of 8 (permalink) Old Jun 10th, 13, 3:56 PM Thread Starter
Curley8788
any schematics available?
1968 Chevelle
post #5 of 8 (permalink) Old Jun 10th, 13, 4:45 PM
Bart
(When upgrading from OG alt to CS130) Not to steal the thread but I read the tech article on this website AND it says to connect the outside wires on the voltage regulator together - but it shows them as being blue and brown. On my '69 Im almost positive theyre red and red.......one with a fusable link.
Do I still do as the tech article says?
1969 Chevelle Malibu 396BB, DNE2 4speed (do not want - would sell), 12 Bolt, 18x9.5 Snettertons with 245/40 and 285/35s Conti3s.
My Build thread -
Wanted - 2" Cowl Hood. Would trade my 4".
barrrf is offline
post #6 of 8 (permalink) Old Jun 10th, 13, 5:12 PM
Hank
Are you looking at the horn relay or the voltage regulator. The main splice off the horn relay, that feeds the fuse box, has a fusible link. No real current going through the voltage regulator and it does not require a fusible link.
Hank
Finally is offline
post #7 of 8 (permalink) Old Jun 10th, 13, 9:32 PM Thread Starter
Curley8788
this is what i did, along with a 4 gauge from the battery negative to the frame. now i have no real voltage drop which is great. I will have to check it with the fans on though...
also, my alternator is a DR44 style which is normally computer controlled. Since i have no computer, my only option is to hook it up one wire, which it's output defaults to 13.8 volts. Do you see any problem with 13.8 volts to the battery vs the normal 14.4?
1968 Chevelle
post #8 of 8 (permalink) Old Jun 11th, 13, 4:05 PM
Steamy
Wink Re: Upgrade horn relay and wiring? High amp alternator
The voltage regulator #3 terminal has a 20 ga orange colored fuse link to protect the field circuitry and generator warning light. The #3 terminal is connected to the main charging wire via a splice in the harness.
BillL
My Showroom
Ark68SS is offline
This Thread is more than 2552 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
