67 SS Car - Radio Harness Photo and Question - Help Please - Chevelle Tech
post #1 of 4 (permalink) Old May 12th, 13, 9:05 PM Thread Starter
Mark
The attached photo shows part of the radio speaker harness from my 67 SS car. When looking at the photo, the harness plugs on the left side (green, black and yellow) plug into the back of the AM Radio, also connect to the front speaker and ultimately into the main harness. The wires on the right (white, green and black) go to the radio "fader/toner mechanism. My question is related to the dark blue wire in the middle of the photo which is protruding from the connector that leads to the wires that plug into the main harness, the front speaker and the back of the radio. This wire was cut when I purchased the car with bare wire exposed. I am trying to find out where this single dark blue wire connects and my wiring schematics don't even show it. Is it possible a single wire lead that goes to a rear speaker??? Any help is appreciated. Thanks, Mark
Name:	Radio Harness.jpg
mbondoni is offline
post #2 of 4 (permalink) Old May 13th, 13, 7:57 PM
Bill Wente
Re: 67 SS Car - Radio Harness Photo and Question - Help Please
Yes, the dark blue wire runs to the rear speaker.
67since67 is offline
post #3 of 4 (permalink) Old May 13th, 13, 7:57 PM
Smile Re: 67 SS Car - Radio Harness Photo and Question - Help Please
You are correct. Single blue wire is for a rear speaker.
Good luck
s5757s is offline
post #4 of 4 (permalink) Old May 13th, 13, 9:19 PM Thread Starter
Mark
Guys, THanks for clearing up the confusion. If the dark blue wire is the "hot" to the rear speaker, where do I ground the rear speaker? Do I just run a small lead from the speaker to ground? Thanks again, Mark
mbondoni is offline
This Thread is more than 2481 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
