Hei help - Chevelle Tech
post #1 of 7 (permalink) Old Feb 23rd, 13, 3:10 PM Thread Starter
ken
Hei help
Can someone tell me what the black & gray wires are for on new HIE GM distributer (pt # 88961867) I have the normal three wire plug in connecter plus the two extra. Are the for a rev limiter?
Thanks,
Ken
ford179 is offline
post #2 of 7 (permalink) Old Feb 23rd, 13, 3:48 PM
leo
Re: Hei help
got a pic?
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 7 (permalink) Old Feb 23rd, 13, 6:09 PM Thread Starter
ken
Re: Hei help
Thanks for your reply Leo, hope this pic helps.
ford179 is offline
post #4 of 7 (permalink) Old Feb 23rd, 13, 6:59 PM
Craig
Re: Hei help
black is engine ground...grey is tach output. Go to msdperformance.com to see how to program your rev limiter if the HEAT 83647 module is in your dist.
DeLong1 is offline
post #5 of 7 (permalink) Old Feb 23rd, 13, 7:33 PM Thread Starter
ken
Re: Hei help
Thanks Craig,
What fooled me is the paper work that came with my ZZ427 says that the distributer included with this engine is now equipped with an alternative tachometer feed (green wire) and rev limiter. The rev limiter has been pre-set to the recommended MAX RPM for the engine (6500 RPM). Problem is there is no green wire..??
ford179 is offline
post #6 of 7 (permalink) Old Feb 23rd, 13, 8:39 PM
Craig
Re: Hei help
I got the ZZ427 too and in the paperwork that came with it said it had a rev limiter that was preset to 6500. I went to the MSD website and downloaded the install instructions for the "MSD HEAT Digital HEI Module, PN 83647 . This explaines the setup quite well.
DeLong1 is offline
post #7 of 7 (permalink) Old Feb 24th, 13, 6:19 AM Thread Starter
ken
Re: Hei help
Thanks guys, downloaded the install instructions which explained everything.
ford179 is offline
This Thread is more than 2423 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
